Front suspension air valve removal?
Old Jun 18, 2014 | 11:04 AM
Road Star's Avatar
Road Star
Default Front suspension air valve removal?
Can this be done? Can I eliminate the air fittings and Schrader valves, and run progressive springs?
Anyone else here done this? Any special parts required?
Old Jun 18, 2014 | 01:05 PM
bikehunter's Avatar
bikehunter
Progressive spring cartridges you can, if you buy just the spring kit, it would have no caps to use instead of air caps.
Old Jun 18, 2014 | 02:38 PM
Road Star's Avatar
Road Star
Is that a better way to go, than the stock setup?
Old Jun 18, 2014 | 03:42 PM
Leftcoaster's Avatar
Leftcoaster
Just plug the caps and install the springs.
Old Jun 18, 2014 | 08:20 PM
Road Star's Avatar
Road Star
But, do I need to buy cartridge style springs?
Old Jun 19, 2014 | 08:32 AM
bikehunter's Avatar
bikehunter
TBO, if you just plug the caps, your suspension will be soft. There's probably only two possible ways with the standard setup.
1/ install another spring set but you may require air as well.
2/ Add a Cartridge setup.
Another way may be to add thicker oil to get better damping but air is required again.
Old Jun 19, 2014 | 10:13 AM
Leftcoaster
Progressive makes longer springs for those that remove the air assist. Cap the holes, install the springs and add fresh fork oil and you're golden.
You will like the difference in ride quality.
Old Jun 19, 2014 | 12:57 PM
bikehunter's Avatar
bikehunter
Cool, there you go perfect solution
Old Jun 19, 2014 | 01:39 PM
Road Star's Avatar
Road Star
Thanks. I'll call progressive...
AlCherry
EVO
Dec 17, 2018 11:16 AM
HarleyX89
Jan 9, 2017 11:42 AM
ranger fan
EVO
28
Oct 27, 2010 12:29 AM
Mario77746
Jul 21, 2009 08:28 AM
HDawg
Dec 2, 2005 01:32 AM
