Changed Levers, No Front Brakes?
Old Jul 12, 2014 | 08:45 PM
Warbird40's Avatar
Warbird40
Default Changed Levers, No Front Brakes?
Something strange has happened. I changed my old levers with some chromed ones and now I have no pressure on the lever on the front brakes. I left the house and after using my brakes at 3 stop lights, my front brakes started to "stick/drag" until the calipers completely closed as if I was holding the lever. I opened both nipples briefly to get them to open and rode back home. I tried bleeding the brakes, but because I have no pressure at the lever, I can't get them to "bleed". I also tried to do the reverse bleed and nothing. I am confused since they were working perfectly before changing levers, and as all of you know, changing levers is not rocket science. Thanks
Best regards,
Ed
Old Jul 12, 2014 | 11:24 PM
DDuess's Avatar
DDuess
I just read a recall about this. The chrome prevents the full return of the master cylinder piston and causes the front brake to drag, heat expands fluid and applies brakes.
Old Jul 12, 2014 | 11:36 PM
Warbird40's Avatar
Warbird40
Now you got me thinking that I should put the old brake lever and test it.....I will try that in the morning to see if its that.
Thanks
Old Jul 13, 2014 | 12:24 AM
mkguitar's Avatar
mkguitar
hope you used a shim on the brake light switch.
mike
Old Jul 13, 2014 | 12:56 AM
Warbird40's Avatar
Warbird40
mike
A shim? I installed it they way it came.....so no, it looked like the original and I installed it the same way
Old Jul 13, 2014 | 06:09 AM
lp's Avatar
lp
A temporary shim (cardboard) is placed between the lever and the housing to ensure that you don't brake the tip off the brake switch during lever installation.
It's not something that would not affect brake line pressure.
Yes, install your old lever and see what gives...
lp
Old Jul 13, 2014 | 01:04 PM
Warbird40's Avatar
Warbird40
Well everything with the switch is fine, could my master cylinder have gone bad? I don't see how it could have taken a crap on me from one day to the next. I did notice a small noise when applying brakes (kind of a small electric current or "white noise") coming from the MC, so not sure if that was a sign that it was going bad. I removed the bajo bolt to the MC and when I press on lever, no fluid comes out of MC port.
Old Jul 13, 2014 | 01:29 PM
mkguitar's Avatar
mkguitar
that was a test to see if you have the manual...
the shim referenced is required on models the past 30 years to prevent the switch tip breaking- a $60 part ( some have fixed with jb weld).
a busted switch tip may jam up the lever to master cylinder interference.
Mike
Old Jul 13, 2014 | 01:42 PM
Warbird40's Avatar
Warbird40
The switch is fine, just dont understand why there is no pressure
Old Jul 13, 2014 | 03:16 PM
FinalShot's Avatar
FinalShot
I had something similar on a cager years ago...
How old is the brake fluid? What I experienced in the past was that I changed out some parts of the brake system and being that it was only a couple years old I didn't think I needed to change the fluid. What was happening in my case was that the brake fluid had moisture in it. With both front calipers dragging just a bit, it was enough heat to cause the moisture in the fluid to boil and cause very spongy brakes. After I drained the fluid, cleaned the calipers and flushed the system real well, the problem went away.
Just a thought....
