I am not an engineer so this is pure speculation on my part, gleaned from decades of experience. There are a number of things going on in the primary case of a Harley. Probably the thing that gives more owners trouble over the last 10 years is the damn compensator assembly. It has been redesigned by the MOCO at least 3 or 4 different times in the last 10 years that I know of. The latest design being for the 2014 model touring bikes. I still hear from owners who continue to have problems with their new compensators. At this point it is probably too much to hope for that the crack engineering team at the MOCO would just throw out the compensator assembly and come up with something like everyone else uses and has relatively few problems with.
The problem for the most part continues to be that fact that lubricating oil has a very difficult time of lubricating all the compensator parts that need lubrication.
The last thing I would want to do is put a heavy oil in the primary. In this case I think it would be prudent to run a light oil in there which is exactly what the Formula Plus is.
Same goes for the gear box. Heavy oil is not always the thing you want.
Harleys aren't 80,000 lb vehicles cruising at 70 mph all day and night long, racking up a million miles. Those kind of applications can benefit from a 140 weight oil, but certainly not our little 1000 pound motorcycles.
I liked your post and wanted to add some things about big rigs as you mentioned them. A Heavy Haul Truck may gross out at 240,000 lbs, they run 50 wt in the trans and can use 75/90 in the Differentials. most all gear manufactures are going to lighter oils, it gets where it needs to be quicker and provides the same lubrication as the heavy stuff.
UHHH! What country are you from where a truck can gross out at 120tons? In US its generally 80k and some states allow 100 or 110k. Mfg's may be going to lighter oils but the priority in a gear lube is shear factor under stress then lubrication, any fluid will act like a lubricant up to a point.
While I stick with F+ the myth that sny in primary will hurt the clutch is just that a myth. Urban legion. Has no bases in fact or the real world.
It's not a myth that synthetic makes the clutch slipperier, there are a bunch of us who felt the problem when we switch to syn, and felt it change back to normal when we switched back to F+. There is a thread on it somewhere, but I can't remember the title of it. I'm not saying synthetic is bad for the clutch, just that it makes it slipperier and feel different. For many of us, different is bad.
Keep in mind it was published by AMSOIL but it compares many different 40 and 50 weight motorcycle oils. Note that HD SYN 3 and HD 360 plus Amsoil and Mobil1 are located on all the 50 weight charts:
You know very little about Trucking, We have trailers that weigh 80k, we load 70 ton M1A1's on them and haul them all over the USA.
No I do know a lot but what you mention is not the norm and thats probably 1 in 50k trucks that haul that big of a load. you gave the perception thats all trucks haul at that limit.
when I bought my bike it has syn3 in all 3 holes, I didn't like how the bike performed so I went with Amsoil shockproof 90/140 or in the trans, mobil 1 v-twin 20/50 in the engine and formula+ in the primary. this is the best combination for me so far.............
Not sure why you picked out my post to pick on, but if you read it again, I did say " Heavy Haul " trucks. Nothing more to see here folks lets move on.
Well I'm a total heathen - Mobil 1 15-50 in the crank, RedLine Hvy Shockproof in the trans, and Dexron ATF in the primary......it's a miracle my '05 will even start after that kind of abuse! ;-)
