Baffles removed and fixed
I have a 13 Road Glide and cut the baffles out and removed them. The sound is amazing. I haven't heard a bike with aftermarket mufflers/headers that I like better. It's a deep, throaty, raw sound. You can really hear the Harley coming out of them. I noticed that yes, I lost a TINY bit of torque from the loss of back pressure, but not much for me to notice except when I cranked on the throttle to get it up and moving such as passing someone. But again, barely noticeable. I did however want to correct the problem. NO, this isn't an advertisement. I don't care what you put in your bike. But I bought so baffles from Big City thunder to put in the pipes. I was actually surprised because all it is, is a piece of pipe about 3 inches long with what looks essentially like an electrical lug welded on the inside. I was skeptical about their claim of getting the back pressure back again, but installed them and they work perfectly! The sound has not changed, except now I don't get the back fires and pops anymore, and the torque is definitely back to normal. I think it was more noticeable then I had thought. But now I'm loving the sound and the performance. Some of the questions i had answered on my own? No noticeable loss in MPG, no engine issues or any other kind of damage happened. I had straight pipes with no baffles on for about 6 months and 6-7,000 miles. The only thing I didn't like was the back firing (not very loud, just the popping on decel) and the minimal loss of torque. So if someone out there is contemplating the mod, I say go for it! it worked out well for me. but definitely try to fix the back pressure issue. The Big City Thunder baffles worked perfect for me, but if I were a welder, and knew better, I would have just welded in something like a lug to the inside of the main pipes. Again, just my 2 cents, and something I thought I'd share.
I thought about Big City Thunder baffles but having used DK TTI's before decided on them. I think a lot of people tend to overlook that stock mufflers are actually expensive slip ons that just have baffles most of us do not like. Using my dremel with cutting wheels it took me under an hour to remove the stock baffles and put in the lollipops. I did leave in the metal mesh though to help add some resistance as the exhaust is funneled back in from the TTI's.
