Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Bank Angle (tip) Sensor Problems, Anyone else?
Old May 13, 2016 | 08:33 AM
Gunnysgt's Avatar
Gunnysgt
Default Bank Angle (tip) Sensor Problems, Anyone else?
Since I got my TriGlide I've had the tip sensor go off way too many times. First time was drifting it out of the garage on a small grade and turning 90 degrees then stopping. Didn't know why it wouldn't start til I saw the odometer said E ip which I figure supposed to say Tip. Have to recycle the ignition several times to make it go away and start again. Since then I've had it go off several times. I mean why the hell would you even want a tip sensor on a trike to begin with. Anyone else have this issue or is mine some sort of anomaly.
Old May 13, 2016 | 10:52 PM
Moe55's Avatar
Moe55
Check to see if it came loose or one screw came out. It is next to the battery on the 14's guessing it is in the same place on 16's.
Old May 14, 2016 | 12:37 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I think something must be awry.
I've been at some pretty significant angles and never had it trigger. It should really only trigger if the Trike were to go on its' side or upside down.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old May 14, 2016 | 02:48 PM
screwball's Avatar
screwball
IF I'm not mistaken (and I frequently am) the tip switch or whatever Harley calls it is a safety thing for most fuel injected vehicles. All my Fords have them to turn off the fuel injection pump in case of roll-over. Most times you roll or drop your bike the ignition is on, electric fuel pump is pumping..... or so I am told
Old May 15, 2016 | 03:04 AM
msocko3's Avatar
msocko3
You are correct, they also use it on 2 wheels bikes to cancel the turn signals by sensing lean.
Old May 16, 2016 | 10:49 AM
bigfish_Oh's Avatar
bigfish_Oh
mine when bad and was replaced at 600 miles
Old May 20, 2016 | 09:27 PM
Gunnysgt's Avatar
Gunnysgt
Just got back from Myrtle Beach Bike week, I'm takin it to the dealer to have it replaced via warranty. Just curious if anyone else had this or mine was an anomaly
Old Jun 8, 2023 | 07:03 AM
Matsavinh's Avatar
Matsavinh
Stage I
Default My bike does the same
I bought my bike 2 years ago and this year. My bike decided the tip center went on and I cannot get it off. I have done everything including buying a new tip censor anyone? Got. Any? Ideas. I've already reset the bike other than replace the bank angler. I've done everything.including changing the filters. My thought is possibly electrical at this point
QUOTE=Gunnysgt;15141091]Since I got my TriGlide I've had the tip sensor go off way too many times. First time was drifting it out of the garage on a small grade and turning 90 degrees then stopping. Didn't know why it wouldn't start til I saw the odometer said E ip which I figure supposed to say Tip. Have to recycle the ignition several times to make it go away and start again. Since then I've had it go off several times. I mean why the hell would you even want a tip sensor on a trike to begin with. Anyone else have this issue or is mine some sort of anomaly.[/QUOTE]
mine also
Old Jun 8, 2023 | 07:14 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
You will be better off starting your own thread stating all the details of your machine but if you want to continue here all the details are needed to know anything about what you are dealing with.
Welcome to the forum.
Outamyleague
Nov 4, 2015 11:57 AM
Bill12205
Sep 25, 2014 07:33 PM
02fx4dude
May 15, 2013 07:17 AM
07bagger
Jun 19, 2011 09:22 PM
Biker Trash
Apr 10, 2008 05:52 AM
