Warm film with hairdryer.then start an area with hotter air,don't over do it and don't burn your fingers.Put WD40 on residue and let it sit wipe off and good to go.
I thought it was to protect the paint from damage from gravel and other small road debris?
My fenders have several chips from gravel and other small road debris because I didn't have anything to protect the paint on my 09, didn't see the protective stuff till after the chips were there.
I removed the rear fender clear plastic protectors mostly because they aren't the full width of the fender. I ended up with chips on the outside edges anyway. Plus, the edges of the plastic were slightly crinkled. I kept some of the other pieces on the bike.
Since I didn't use all of the pieces in the kit, I used some extra plastic to put protection on the left and right corners of the tank where my levi's rub the tank while riding - cut out a shape I liked and it worked out very well.
By the way, WD-40 didn't soak the glue off when removing the plastic, but brake cleaner did, but I still had to polish the fenders when finished.
Got to be careful on what brake cleaners you use on paint, I've had some which would wrinkle the paint. I try to get the non flammable CFC free, they seem a little more gentile.
