Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Pullback handelbars 2014
Old Nov 4, 2013 | 10:56 AM
dwludwi's Avatar
dwludwi
Default Pullback handelbars 2014
Has anyone put the Harley 2" Pullback (reduced reach) handlebars on their 2014 Tri-Glide? Did you have to put on different clutch or brake hoses? One of the local dealers says that it would need different hoses.
I did see in the touring forum where 2014 Limited owners have put on these handlebars with no changes in hoses.
Old Nov 4, 2013 | 02:29 PM
sloufoot's Avatar
sloufoot
Sounds like a CYA by the dealer. They probably don't know if you will need them or not, but just to be sure they will put on longer hoses. But not every install is the same.
For instance I put those bars on my '12, & I didn't have to change anything or re-route anything.. Others doing the same install ended up changing almost everything for extra length. Could be that someone told them they had to....... Don't know.....
Old Nov 4, 2013 | 03:51 PM
5x40's Avatar
5x40
as sloufoot has stated. before I had mine done on my 2013 last yr, I asked the same questions. was told by sloufoot and others, "No." based on their input when I went to the dealer to have the install done, I asked the SM if I needed new cables, he too said, "No."
thinking back, we did have to wrap the left handlebar w/tape before installing the grip as the new bars are a RCH smaller in dia than OEM handlebars...
Triker 2
Sep 19, 2014 09:20 AM
rvnkontum
Jan 2, 2014 04:39 PM
jay72
May 31, 2012 03:35 PM
SSTuner
May 9, 2012 02:40 PM
MangoMike
Nov 1, 2009 10:01 AM
