how tight should front axle nut be
Old Sep 17, 2012 | 07:58 AM
byaj's Avatar
byaj
Stage III
Default how tight should front axle nut be
Just joined and have question about front wheel on 94 sportster. if i tighten to 55ft-lbs then the wheel won't turn easily by hand. sholuld i just tighten the axle nut so the wheel still turn easily and go with that?
Old Sep 17, 2012 | 08:02 AM
2011Deluxe's Avatar
2011Deluxe
Welcome!
Old Sep 17, 2012 | 09:52 AM
ceebaileys's Avatar
ceebaileys
Former Sponsor
Welcome from sunny Southern California
Old Sep 19, 2012 | 11:13 AM
Longhair4life's Avatar
Longhair4life
Welcome
Old Sep 19, 2012 | 11:41 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Welcome to the HD Forum from the sunny shores of SoCal.
Old Sep 19, 2012 | 12:47 PM
Big Trev's Avatar
Big Trev
No there's something wrong with you set up, have you had it apart?
Old Sep 19, 2012 | 01:12 PM
ceebaileys's Avatar
ceebaileys
Former Sponsor
Old Sep 19, 2012 | 01:14 PM
jamesw's Avatar
jamesw
Almost sounds like the "spacer sleeve /spacer washer / washer" setup is a little too short for proper bearing clearance? Did you change bearings?
http://partsfinder.onlinemicrofiche....NT-%28LACED%29
Old Nov 23, 2012 | 12:56 PM
Imold's Avatar
Imold
First, when you ask questions here, helps to know all you've done to get to the problem. I'm guessing you had the wheel off, but what about the bearings? Worst case I can think of here would be not putting the wheel hub spacer (long tube) in between the bearings; you could wreck the bearings tightening up without that. I'd guess you just didn't get the spacers or speedometer pickup just right, and that wheel may have shims, too. When you get the nut snug just enough to start feeling the bind (don't torque it again till you find out what the problem is), check to see if the wheel looks centered, that it's not rubbing a fork or fender, and try to see if the brake pads are flush against the rotor - if one end of the pad is touching and the other has an air gap (this is on the same pad), that would also indicate the rotor isn't lining up, which would mean the wheel isn't, either; that might be visible before you could tell the wheel was slightly off.
If you replaced the brake pads, you might not have the caliper pistons pushed far enough back, although it's usually really hard to get the caliper back over the rotor that way; also, loosening the axle nut might not let it turn any easier.
Here's an illustration of how the wheel is supposed to go back together, in case you don't have one. There are lot's of illustrations like this on the internet, if you don't have a manual. If you have a cast wheel, it will have a 5 bolt hole plate on the right side (opposite the rotor), that isn't shown in this illustration.
Old Nov 23, 2012 | 01:17 PM
the wild hog's Avatar
the wild hog
Welcome from the Sunshine State.
anything2wheels
Oct 1, 2016 09:13 PM
Fine09
Jun 17, 2016 10:43 AM
FXDForbes
Jun 23, 2014 03:59 PM
CGLTD
Mar 30, 2009 10:38 AM
eventiller
Oct 20, 2005 03:58 PM
