Wheel alignment?
Old May 11, 2017 | 07:53 PM
REW13's Avatar
REW13
Default Wheel alignment?
Wheel alignment off will this be an issue?
Rims were just put on the bike, tire was on the rim already, so could the tire have been put on the rim backwards?
Old May 11, 2017 | 08:22 PM
multihdrdr's Avatar
multihdrdr
Take a good pic showing the hub right where it meets the brake rotor.
(this is for wheel identification purposes)
Old May 11, 2017 | 08:26 PM
REW13's Avatar
REW13
Should I be looking for any markings? Numbers or letters
Old May 11, 2017 | 08:27 PM
multihdrdr's Avatar
multihdrdr
No...just appearance
Old May 11, 2017 | 09:20 PM
REW13's Avatar
REW13
Will get it posted tomorrow.
Old May 11, 2017 | 10:37 PM
multihdrdr's Avatar
multihdrdr
I remembered you had posted a pic of your wheel in another thread
Look a the casting surface here (below)
See Below...Does it look like the top photo or a machined surface like the lower photo? (i think it's the top...yes?)
Old May 12, 2017 | 11:41 AM
REW13's Avatar
REW13
Here's the rotor and pulley side.
Thank you
Old May 12, 2017 | 12:18 PM
multihdrdr's Avatar
multihdrdr
I originally was thinking you had a 03-06 softail wheel which would cause the symptons you describe, but after seeing your wheel in the pic I posted and then your following confirming pics, that doesn't seem to be the case.
How bout a good pic showing how centered the brake rotor is within the caliper
Does it look centered to you?
Old May 14, 2017 | 10:28 AM
REW13's Avatar
REW13
Not sure if this is what you were talking about? I went on a ride after the rain here, found some nice dry wet spots and rode through to check my tracking. It was straight?
Old May 14, 2017 | 11:13 AM
multihdrdr's Avatar
multihdrdr
Hard for me to see from where I sit...Does it looked centered?
Use your pistons as a reference
