Xtreme machine wheel bearing?
Old Jun 12, 2017 | 06:25 PM
2deuceguy's Avatar
2deuceguy
Default Xtreme machine wheel bearing?
Hey guys, I'm in a bind with a bike I'm working on. 2003 softail deuce. The bike has Xtreme machine spade wheels on it. I need to install new wheel bearings but the ones I pulled out are not the right size. It's a 3/4" (19mm) axle and the bearings I pulled out were 20mm. The bearing bore in the wheel is 47mm. Factory size for this bike is a 52mm OD on the bearing. I called Performance Machine and they said they use a 52mm x 15mm x 3/4". They stated if it's an older wheel the dimensions may be different but couldn't tell me what they might be. Anyone have any advice on where I should go from here?
Edit: the bearing bore in the wheel is 47mm wide and 16.5mm deep.
Old Jun 12, 2017 | 06:55 PM
lightweight bob's Avatar
lightweight bob
PM uses Nachi / Japanese bearings that they get from this supplier. Might want to
check with them for a recommendation.
http://www.vxb.com/NACHI-FUJIKOSHI-C...FY6cfgodVFsOzw
Old Jun 12, 2017 | 07:24 PM
2deuceguy's Avatar
2deuceguy
I'll check that out thanks
Old Jun 12, 2017 | 10:24 PM
multihdrdr's Avatar
multihdrdr
Maybe this will help. It's a "Special"
6204-2RS-3/4
.... 3/4"ID x 47mm OD x 14mm wide
http://www.allballsracing.com/6204-2rs-3-4.html
You'll get HITS searching for 6204-2RS-12 or 3/4 ... (12 is 12/16ths or 3/4)
Old Jun 18, 2017 | 09:51 PM
multihdrdr's Avatar
multihdrdr
Boo!!
Old Jun 24, 2017 | 10:07 AM
2deuceguy's Avatar
2deuceguy
6204-2RS-3/4
Thanks I got those ordered.
Old Dec 21, 2017 | 10:27 AM
Don13's Avatar
Don13
Stage I
hi was just wondering if those bearings worked out. I'm looking to change bearings on a xtreme machine wheel also
Old Dec 21, 2017 | 10:32 PM
2deuceguy's Avatar
2deuceguy
They did but I had to get a spacer kit and respace the wheel. If you still have the original bearings in yours you should measure the thickness and post back here.
sbrmike
Wheels/Tires
Mar 9, 2018 04:20 PM
DanDman
Wheels/Tires
Nov 25, 2012 09:48 AM
jrcisu79
Wheels/Tires
Mar 5, 2010 09:23 AM
07bobber
Jan 3, 2010 09:09 AM
Z
Sep 5, 2006 11:45 PM
