16” rear on a dyna
Old Apr 13, 2018 | 10:09 PM
Nate8604's Avatar
Nate8604
Default 16” rear on a dyna
I just got a set of amf 9 spoke wheels off a guy locally. The front is 19” and the rear is 16”. Other than a new rear tire what will I need to make this set up work? I don’t have abs if that makes a difference.
Old Apr 13, 2018 | 10:14 PM
2500hdon37s's Avatar
2500hdon37s
how are we suppose to know, if you dont tell us what you're trying to put them on?
Old Apr 13, 2018 | 10:16 PM
Nate8604's Avatar
Nate8604
my bad 13 fxdb
Old Apr 13, 2018 | 10:45 PM
Nate8604's Avatar
Nate8604
The wheels are from an fxr
Old Apr 14, 2018 | 08:43 AM
multihdrdr's Avatar
multihdrdr
Might be wrong, but I don't think you're going to want to do what it will take to install those 99-earlier (technically 9-spoke is 95-earlier) wheels with 3/4" Tapered wheel bearings on your 25mm sealed bearing mid-glide bike
Old Apr 14, 2018 | 10:01 AM
Nate8604's Avatar
Nate8604
Can’t just swap bearings?
Old Apr 14, 2018 | 10:07 AM
multihdrdr's Avatar
multihdrdr
Swapping bearings wouldn't fall under "do what it will take to install", that's simple stuff
No, the Tapered Bearing and Your Sealed Ball bearing have different ODs (outside diameter)
You would have to stay with the 3/4" and work around that
Old Apr 14, 2018 | 10:17 AM
Nate8604's Avatar
Nate8604
what about machining to match the od
Old Apr 14, 2018 | 10:22 AM
multihdrdr's Avatar
multihdrdr
Maybe, but you would lose your pulley/rotor locator on the hub
Old Apr 14, 2018 | 11:53 AM
Nate8604's Avatar
Nate8604
you’re right I just went down to one of the shops I use and he said not gonna happen without milling a premade set of bearings.
gmkavas
General Topics/Tech Tips
Feb 12, 2019 02:49 PM
artsbest
Dec 24, 2018 09:31 PM
fenwick
Dec 3, 2018 05:12 AM
No U Glider
Oct 23, 2018 05:13 PM
bykw2
Jan 8, 2018 12:31 PM
Slideshow: Harley-Davidson's new RMCR concept revives the cafι racer formula with modern hardware-and it may be exactly the reset the company needs.
