Dyna wheel bearings
Old Dec 26, 2018 | 11:16 PM
04Fxdl87's Avatar
04Fxdl87
6th Gear
Default Dyna wheel bearings
Whats going on guys just trying to get some clarity on wheel bearings. Been told couple things seeing if anyone done it. I have a 04 fxdl with spoke wheels. I was told has 1 inch bearings front and rear and iv been told 1inch front and 3/4 rear, just had surgery so havent pulled them apart yet. my buddy has some mags i want to pick up and throw on but there 3/4 bearings. Is it as easy as removing and replacing with my size bearings and spacers or are the completely different? thanks
Old Dec 26, 2018 | 11:59 PM
04Fxdl87's Avatar
04Fxdl87
6th Gear
Default dyna wheels
Old Dec 27, 2018 | 01:01 PM
multihdrdr's Avatar
multihdrdr
Yes, 04-05 Dynas (except for WG) have 1" Front and 3/4" Rear axles.
What bike did your buddy's "Mags" come from?
If the FRONT is an Original wheel from a 3/4" axled bike (2000-07 Sportster / 2000-03 Dyna ), you'll have to enlarge the "Clearance" Hole for your larger 1" axle/spacer sleeve
Old Dec 27, 2018 | 10:57 PM
damo14's Avatar
damo14
as long as the hub is the same width your good to switch the bearings and spacer
Old Dec 28, 2018 | 09:03 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
The bearings used on your year/model has H-D pn 9247 front and 9267 rear.
Measurements for 9247 (front):
ID 1in x OD 52mm x Width 21mm
Measurements for 9267 (rear):
ID 3/4in x OD 52mm x Width 21mm
Check out this link for detailed parts diagrams...
Old Dec 28, 2018 | 10:47 AM
multihdrdr's Avatar
multihdrdr
Your other Thread ... (Wheels/Tires section)
https://www.hdforums.com/forum/wheels-tires/1265343-dyna-wheels.html
EDIT: Well ... now the two threads have been combined
Old Dec 29, 2018 | 06:23 PM
04Fxdl87's Avatar
04Fxdl87
6th Gear
The mags are off 01 dyna
Old Dec 30, 2018 | 07:42 AM
FXD2003Rider
According to this 2001 DYNA MODELS PARTS CATALOG 01 Dyna cast wheels front & rear have p/n 9267 (ID 3/4in x OD 52mm x Width 21mm)
Rear wheel should be a direct fit.
03 cast front wheel needs the 9247 bearings. As far as I can see in the parts diagrams all other parts on your '04 FXDL like axel, spacers etc. can be reused on the cast front wheel.
Funky Monk
Nov 10, 2020 01:45 PM
Dizzzy
Jan 12, 2020 11:29 AM
sbrmike
Wheels/Tires
Mar 9, 2018 04:20 PM
GearHeadedWeerdo
May 7, 2015 07:08 AM
BuddyK
Wheels/Tires
Sep 6, 2014 10:26 AM
