Balance Issues
Old Sep 22, 2020 | 09:23 AM
Olmoose's Avatar
Olmoose
2nd Gear
Angry Balance Issues
How often do you guys find your tires out of balance enough to be noticeable? back story here, 2018 Ultra (18K total miles) replaced F&R at 15K with the Dunlop Elites. At about 100 miles in, ran over bolt with rear. Sucks but after plugging it (all good for 1000 miles) my Wife refused to ride with me till I replaced it. OK, replaced at a local dealer with winter killer deal. After several rides it was apparent something amiss. Had warranty work done at another dealer and I asked them to check the balance. It was off A LOT. Seems original installer never balanced or removed original weights. So, rebalanced all groovy for another 1000 miles. Now. seems to be vibration once again. Never had this issue before. Just my luck? Wondering if maybe the previous miles on the originally unbalanced tire has created a less than perfect surface area.
Thanks as always in advance.
Olmoose
Old Sep 22, 2020 | 10:37 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
It has nothing to do with the last tire that was on the bike.
Pull the wheel, make sure the wheel bearings are good, and have it re balanced.
Have the shop check the balance first (without removing the weights), to see how much unbalance you actually had.
Old Sep 22, 2020 | 10:41 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I have been out with a couple of people who have had tyres fitted at a well known indy here. The wheels are not balanced and the riders do not notice any problems. The guy at the shop told me he never balances the rear wheel and has never had any comeback.
Old Sep 24, 2020 | 06:52 AM
bustert's Avatar
bustert
balance is important as it adds to tire life. running a couple k with it not balanced would not be a killer unless it was severe enough to damage the core, then the tire is trash. i highly doubt that is the case. also, the method of balancing can make a diff. machine balance is better than gravity balance. sometimes, you have to split the weights because at certain speeds, it can induce a vibration because all the weights are on one side of the wheel.
Old Sep 24, 2020 | 07:06 AM
Andy from Sandy
The company I used was unable to balance the wheel with the belt pulley in place on a dynamic machine. Kind of defeats the object?
Old Sep 24, 2020 | 08:47 AM
Olmoose's Avatar
Olmoose
2nd Gear
You bring up a good point Andy. However, what I find interesting is this is a new condition that hasn't been present when new (off show room floor) or after the immediate rebalancing. Or with my previous Electra Glide. So clearly something amiss.
Olmoose
Old Sep 24, 2020 | 09:06 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Sorry, but I`m going to toss the junk science flag here...
I have balanced a countless number of rotating parts for jet and rocket engines for over 36 years (from compressor modules that weigh 5,000 pounds to tiny rocket turbines that you can hold in one hand) and what you just said is not a fact.
All balance counterweights on one side of a rotating part will not cause an unbalance, if the weight is correct.
If a properly balanced tire/wheel assembly has a unbalance issue at speed, there is an issue with the tire or wheel.
There is no precision to be had in balancing a tire/wheel assembly, about all that can be done is to get rid of the gross unbalance of the rotating mass.
On a rubber tire that is about all you can do..
Old Sep 24, 2020 | 09:14 AM
Rogue1's Avatar
Rogue1
I have to concur with this .The rear tire is the driven tire, constantly under load unless you're coasting. the balance would have to be way off to notice anything.
Old Sep 24, 2020 | 02:07 PM
eighteight's Avatar
eighteight
I mounted all my own tires from 1978 until 2017, never had the equipment or inclination to balance, no ill effects.
Now that I`m a geezer and just drop the wheel off at a shop, they get balanced.
Just my experience
Old Sep 24, 2020 | 11:59 PM
Old_Bikes's Avatar
Old_Bikes
I have never rebalanced a tire after installation and initial balance. I learned about tire balance on my pan chopper with 21-inch front wheel when I first started riding and the springer would start to pogo after about 50mph....
