Broken Spokes
Old Apr 29, 2025 | 08:48 PM
ronscooter2012's Avatar
ronscooter2012
Question Broken Spokes
Did some "bobber style" custom work on a 2002 HD FXST Softail Std. ...Put a new, narrow (swingarm mounted) rear fender and a new 18 inch narrow rear chrome laced wheel. One day while cleaning rear wheel I found 3 broken spokes! (Out of warranty, of course)!!
...Ordered a new one, same brand...and, again, while cleaning rear wheel found a (one) broken spoke!!
Anyone ever heard of this before?.....Am I doing something wrong or are these bad wheels or improperly laced or improperly balanced?? .....(has no rear wobble at all)
.....Don't know what to do at this point!!
Thanks in advance for some advice on this!
Old Apr 30, 2025 | 03:15 AM
eighteight's Avatar
eighteight
Care to share what brand ?
Old Apr 30, 2025 | 07:32 AM
bustert's Avatar
bustert
plus 1 mr. 88
over seas???
if not junk then alignment process was flawed. spokes are forgiving if done correctly, aka, why they are used in moto cross and such.
Old Apr 30, 2025 | 08:31 AM
Architect's Avatar
Architect
Probably not trued properly or spokes were loose. But why did you buy another wheel? You break a spoke, you buy a new spoke and install it.
My '05 Road Glide, when packed heavy, broke two twice on long road trips. After the first event I carried spare spokes in the Tour Pak (my bike had a long and short, carried two of each). Get bike in the air, let most but not all of the air out of the tire, remove broken spoke, insert new into hub and then gently push the nipple into the wheel just enough to insert the new spoke. Air pressure is important, remove enough to push the nipple in but not so much that it falls in and ruins your day. Once screwed in, use the tone method to tighten the same as the surrounding spokes. Check the rest by tone, tighten as needed so they all sound the same. Good luck.
Old Apr 30, 2025 | 02:05 PM
ronscooter2012
Would be glad to.....Hopefully save someone else the "headache"!
....The brand is "Harddrive"
Old Apr 30, 2025 | 02:07 PM
ronscooter2012
Exactly My thoughts!....thanx
Old Apr 30, 2025 | 02:09 PM
ronscooter2012
...Because I've never done that....and don't know anyone who does. :-(
Old Apr 30, 2025 | 02:12 PM
ronscooter2012
....../and THANKS for those instructions!!.....sounds simple enough.
Old May 2, 2025 | 07:40 AM
bustert's Avatar
bustert
in days of olden, i knew guys that could re-spoke and align lightening fast and did use the ting test. while good, these guys did it forever and a day, not so much for a one timer or tone deaf person.
there are a lot of spoke tools out there but the only one i recommend is the nipple wrench, will save battle scars or worse rounded off nipples. torque wrenches are a waste since torque is not consistent.
also use a heavy oil on the threads, does not take much, especially on stainless. the use of dial indicators and a truing stand is a must. you can red neck the stand with a vise and shaft but remember to take all of the axial play out of the bearing assy, the stand has cones for that, and some chalk helps to keep track of position and go slow.
the fsm does have a section on the wheel assy.
Old May 2, 2025 | 08:47 AM
Uncle Larry's Avatar
Uncle Larry
Use Buchanan spokes and be done the first time
ronscooter2012
Wheels/Tires
Apr 29, 2025 08:46 PM
CSS_FXD
Oct 25, 2011 12:20 PM
skyhigh_ct
Jan 13, 2011 10:30 AM
drspencer
Apr 26, 2010 10:28 PM
low_wgn
Oct 31, 2009 02:11 PM
