Touring wheels on fatboy?
Old May 2, 2013 | 05:00 PM
tattoofever's Avatar
tattoofever
Default Touring wheels on fatboy?
So I've been having a ft wheel issue for a while now that's left me wheel less
I have a 2003 softail with a fatboy ft end
I have a 2002 roadking wheel with 1 inch bearings
Has anybody used or tryed unsuccessfully to use a touring wheel on the ft of a fat boy? I know I gotta change over to 3/4 bearings
And I know the rotor fits
Thanks in advance for any help or advice
Old May 2, 2013 | 05:31 PM
tattoofever
That's a big fat no it won't work just tryed it ,the hub is too wide damn can't catch a brake
This year
Old May 2, 2013 | 06:49 PM
tmilo1000's Avatar
tmilo1000
What bike do you have? I know you said a 2003 Softail with a Fat Boy front end. Is the Fat Boy front end on a Train, Duece, Heritage, etc?
Old Jun 19, 2013 | 01:36 PM
tmilo1000's Avatar
tmilo1000
If you can a machine shop with a Bridgeport milling machine, you might be able to have hub milled down to the correct size. You will need to accurately measure the hub width and the space between the forks. It is my understanding the FL front fork on the softail is a little narrower than the FL fork on the touring bikes.
Old Dec 13, 2013 | 12:29 PM
flsoftail's Avatar
flsoftail
Default Front Wheel
Front touring wheel will work, machine shop will need to cut .200" off the rotor side face of the hub, ($40). Cut a couple of new spacers, done. Upgraded mine to the 18" wheel from a 2013 FLHX.
Old Dec 13, 2013 | 12:34 PM
flsoftail's Avatar
flsoftail
Before and after of the wheel.
Old May 28, 2014 | 08:55 AM
flsoftail's Avatar
flsoftail
Default Rear
Anyone know of issues when installing a touring rear wheel on softail? Other than has to be 2007 earlier due to cush drive.
Old May 28, 2014 | 12:34 PM
HarleyArcher's Avatar
HarleyArcher
My cousin put a set of 2006 Ultra wheels on a 2003 Heritage with zero problems. I had to widen the fender just a bit to help fix a minor rub, otherwise nothing to it.
Old Apr 24, 2019 | 06:01 AM
WhiteKnight2000's Avatar
WhiteKnight2000
do you have a finished picture on the bike? also was there any issues with right side fender clearance? I mounted a spoked roadking wheel on my fatboy and the wheel is really close to the right side of the fender.
Copilot
Apr 14, 2013 02:54 PM
Copilot
Apr 14, 2013 02:44 PM
KYfishtail
Apr 28, 2012 08:11 PM
Schmidtty
Feb 13, 2010 10:24 PM
Doughboy
Apr 27, 2009 11:22 AM
