Boom II
Old Feb 13, 2016 | 09:46 AM
mike79's Avatar
mike79
Default Boom II
May be a crazy idea but I want to add the Boom II fairing speakers to my 15 Ultra without adding the amp. Does anyone know if this can be done? Dealer says no. The new speakers need the extra power of the amp to run.
Old Feb 13, 2016 | 09:59 AM
psycko's Avatar
psycko
I would suggest that if you are considering a speaker change then the sound is unsatisfactory to you as it is now. Just do the inevitable and pony up for the amp too. You will be totally satisfied with the whole kit.
Old Feb 13, 2016 | 10:22 AM
hbsoldier3's Avatar
hbsoldier3
You can find all the intell you need here: https://www.hdforums.com/forum/audio-systems-153/
Old Feb 14, 2016 | 07:00 PM
matt76cmich's Avatar
matt76cmich
Default Boom II
+1...
Old Feb 15, 2016 | 05:47 AM
load97's Avatar
load97
You need the amp.
Old Feb 15, 2016 | 06:24 PM
Baeseman1's Avatar
Baeseman1
CAN it be done? Sure...
You can also use racing fuel for your wife's minivan...
Old Feb 16, 2016 | 08:47 AM
dgreen1069's Avatar
dgreen1069
Can't really be done. The speakers require two sets of speaker wires each and a crossover to separate the high frequencies from the low. The normal Boom II system utilizes the amp to adjust the output frequencies. Without the amp, the speakers won't work as intended.
I have the Boom I speakers from my CVO that I'd let go for a reasonable price. I put in an aftermarket system last year after buying and removing the Boom II on my CVO.
I hope this helps. Best of luck.
Old Feb 16, 2016 | 07:47 PM
Mr_King's Avatar
Mr_King
Its simple. They are a bipole speaker and simply need the correct crossover. Its 3000kz high pass for the tweeter and low pass for the mid/woofer. Harley even tells you the frequency here: http://www.harley-davidson.com/store...iring-speakers
Know that without an amplifier the volume will be lower but you can give it a try and then decide if you want an amp.
Good luck.
Old Feb 16, 2016 | 09:54 PM
Rock Woody's Avatar
Rock Woody
I installed the Infinity Kappa 62.11i's with stock head unit in my 14 Ultra Limited. Fidelity is night and day over stock. Was planning amp, but decided to hold off because all the flash issues others were having. Wonder over to the audio forum. There is a lot of excellent information over there and really helpful members. If you are not looking for a much louder system, this worked great for what I was looking for.
WoodButcher66
Audio Systems
Feb 13, 2019 08:04 AM
Geezr Glidr
Audio Systems
Jul 22, 2017 06:59 PM
kmealp
Audio Systems
Nov 13, 2016 09:05 AM
NWI
Audio Systems
Nov 26, 2015 10:05 PM
lowglidin
Audio Systems
Dec 26, 2014 04:21 PM
