2018 flhx p2122 problem
Old Jan 29, 2023 | 11:51 PM
chepeone's Avatar
chepeone
6th Gear
Exclamation 2018 flhx p2122 problem
ive been tackling a 2122 code for weeks, thought it was TGS and replaced it, code came back, went thru several diagnostics and concluded.it was ecu, apparently one of my tests was wrong because after i replaced that, the code came back,
I've did sensor power-1 circuit test,
TPS-1 circuit shorted test
TPS-1 circuit continuity test
TPS-1 circuit short to ground test
TPS-1 circuit short to voltage test
Sensor ground continuity test
TCA test
TCA sensor circuit test
TCA circuit circuit short to ground test
TCA power-1 circuit open test
TCA sensor test
ECM test
TPS-1 voltage test
TPS-1 circuit test
Sensor power circuit test
I'm using a centurion pro plus and I'm stumped, it's probably something I'm overlooking and i don't want to buy another component, has anybody else have these phantom codes, i would appreciate any input.
it's leaving me with a problem with TCA but don't want to just throw parts at it
Old Jan 31, 2023 | 05:53 AM
jake24lt's Avatar
jake24lt
Age old question, did you do anything to the bike before this issue arose? IE: bar swap?
Old Jan 31, 2023 | 12:12 PM
chepeone's Avatar
chepeone
6th Gear
no
Old Jan 31, 2023 | 02:18 PM
Hawg Runner's Avatar
Hawg Runner
Have you tried clearing the code and see if it comes back?
Old Feb 1, 2023 | 12:29 PM
chepeone's Avatar
chepeone
6th Gear
yes, when I'm looking at the screen as the system is running, it will lose communication to ecm
Old Feb 1, 2023 | 05:56 PM
chepeone's Avatar
chepeone
6th Gear
i checked all the connectors and replaced a female terminal in tgs, using live graph on centurion super pro plus, the tgs seems to get voltage up to 5.2v, and momentarily to 5.3v, I'm not sure what is causing this because its a new tgs, and other tests led me to believe it was ecm, which was also replaced, pulling my hair out on this one, what could cause the increased in voltage and also the system is losing communication to ecm
Old Feb 1, 2023 | 07:09 PM
Hawg Runner
Throttle position sensor is what I come up with.
Old Feb 1, 2023 | 07:16 PM
Hawg Runner
Could also be caused by a bad connector, which might explain why you lose the power, check all connectors and apply some dielectric grease to them, and or loose, broken wires rubbing together..
chepeone
Electrical/Lighting/Alarm
11
Feb 8, 2023 03:24 PM
scubaharley
Aug 29, 2008 08:42 AM
refrigerationbiker
Aug 11, 2008 01:24 PM
nemick
Aug 7, 2008 10:58 AM
jbhawley
Jun 11, 2008 05:50 AM
