Tour Pack Squeak
Old Jun 20, 2014 | 09:54 AM
Gunner B's Avatar
Gunner B
Default Tour Pack Squeak
This is my first touring model, so I am not sure if this is a common issue or not. I didn't find anything helpful when I ran a search either. When I close the lid on the tour pack and latch it shut I can hear squeaking. After investigating, I discovered if I grabbed a hold of the latch it quit. Does anyone else have this problem? Do you know of a fix other than having the dealer replace the latch?
Old Jun 20, 2014 | 10:07 AM
PopsHD's Avatar
PopsHD
You're not the only one. Here is a thread I started on the same issue.
https://www.hdforums.com/forum/new-r...squeaking.html
I had the dealer address this issue and they replaced the tour pak hinge. I'm not sure how many miles after the hinge replacement but it started squeaking again. You'll see from the attached thread that most just came up with their own fix, which is what I eventually did. It's sad that a $30k bike has an issue like this but maybe the redesign of the tour pak has something to do with it. I'd let your dealer first address it within your warranty and see what happens. I may let my dealer look at mine again when I go in for the ABS brake line recall.
Old Jun 20, 2014 | 10:54 AM
merlin41's Avatar
merlin41
Mine was making a significant squeaking noise. I took it to the dealer and they found that one of the support brackets for the tour pak was loose. They tightened it up and the squeak went away. It might be worth checking something other than the hinge.
Old Jun 20, 2014 | 02:10 PM
Gunner B's Avatar
Gunner B
Thanks for the help!
Old Jun 20, 2014 | 02:26 PM
Rockgeezer's Avatar
Rockgeezer
Yeah, been talked about many times, I just stuck a thin piece of weatherstripping (maybe 1/8" wide) on the top portion of the latch where the chrome piece clamps down on it and no squeak after several thousand more miles, no need for me to take to a dealer for such a trivial and easily fixed minor thing (at least in my case). YMMV
Old Jun 20, 2014 | 02:29 PM
Gunner B's Avatar
Gunner B
Originally Posted by Rockgeezer
Yeah, been talked about many times, I just stuck a thin piece of weatherstripping (maybe 1/8" wide) on the top portion of the latch where the chrome piece clamps down on it and no squeak, no need to take to a dealer for such a trivial and easily fixed minor thing (at least in my case).
I'll try that tonight. It's a shame that they couldn't get something so small right on a $30K bike.
Old Jun 20, 2014 | 04:41 PM
Yukon42's Avatar
Yukon42
Louder pipes cure the vast majority of the rattles and squeaks. Ear plugs and turning up the stereo are two other alternatives.
Old Jun 21, 2014 | 08:41 AM
Harttoo's Avatar
Harttoo
I taped a piece of duct tape under the top piece of the latch.Squeak is gone .
wheely
May 22, 2014 08:46 AM
remike
Aug 20, 2011 11:29 PM
flhtupser
Apr 21, 2010 08:02 PM
NoTyme
Aug 10, 2009 10:51 AM
Getyurmotorunnin
Feb 27, 2008 08:06 PM
