2018+ Softail Models Breakout
The Everything 2018+ Heritage Thread
Old Dec 20, 2018 | 09:29 PM
  #1171
comanche250's Avatar
comanche250
Default 2019 Softail Sumping
I'm thinking about buying 2019 softail heritage. I've read that the fluid transfer hasn't been an issue with the softail models. Has there been any issues with oil sumping with the softails?
Old Dec 22, 2018 | 05:01 AM
  #1172
sandrooney's Avatar
sandrooney
I have read of 2 And one of them was not sure that was the problem and l did a lot of research on it before I bought my 18 FLHCS. No problems with mine but haven't had it that long. I got it in September of 18 and only have about 5000 miles on it.
Old Dec 22, 2018 | 05:37 AM
  #1173
sandrooney's Avatar
sandrooney
Anybody able to change their pin number on their 18 Heritage. I was told that the dealer had to do it.. I tried the procedure in the manual with no luck.
Old Dec 22, 2018 | 07:22 AM
  #1174
Yzzyx's Avatar
Yzzyx
Yes, I changed mine.
Old Dec 22, 2018 | 07:31 AM
  #1175
kenny55's Avatar
kenny55
No problem changing mine.
Old Dec 22, 2018 | 08:11 AM
  #1176
comanche250
After I posted I found a service bulletin dated nov 2017 about suming issues with the M8 engines. Its Harley service bulletin M1450. It lists affected motorcycles. One affected is all softails with the M8 engine. But it doesn't sound like its wide spreed n the field. The bulletin talks about what part changes harley does to fix the issue.
Old Dec 22, 2018 | 08:16 AM
  #1177
comanche250
Here's a copy of the Service Bulletin about engine sumping.
Old Dec 22, 2018 | 12:04 PM
  #1178
sandrooney's Avatar
sandrooney
Did you go by the procedure in the manual?
Thanks
Old Dec 22, 2018 | 12:08 PM
  #1179
sandrooney's Avatar
sandrooney
I saw that bulletin. I wouldn't worry too much about it. I didn't and I couldn't be happier with my FLHCS. Its a machine anything can happen.
Old Dec 22, 2018 | 12:26 PM
  #1180
comanche250
I agree too. Just heads up. I'm glad Harley put it out there and put any potential issue on paper. Whats odd to me is that the touring M8 engine is a dry sump oil lubrication and the softail M8 is a wet sump system. I wouldn't think that a wet sump system would have any "sumping" issue since by design it wouldn't even need a scavenge pump to remove oil from the crankcase. A wet sump system wouldn't have an oil tank to pump oil back into.
The issue seems much more prevalent in the touring M8.
