I put these Kuryakyn K5773 Phantom Mini Boards on and as you can see from the first photo theyre way to close to the brake pedal even in the furthest hole!
So I switched sides and its now a lot better, even though they're facing the wrong way I think it still looks ok .
In the photo theyre in the middle hole. Last night I moved them down to the hole in the end its even better again.
You can adjust the stock brake lever to be a little higher, about an inch or so. There's a clevis on the back that can be adjusted. It made enough difference that my Thrashin Supply mini floorboards have been fine for tens of thousands of miles.
Thanks mate, I had already adjusted it as far as I could before those photos were taken, so there is no more i can do.
