2018+ Softail Models Breakout
The Everything Fat Bob Thread
Old Mar 2, 2020 | 05:59 PM
  #731
modular's Avatar
modular
Yup, I'm stoopid.....LOL. I had them installed all wrong.....Bwahahahahahaha!!!!! All fixed. Switched everything to right when I got home this evening. See the below emails from Charles at CJM..........
"That is definitely upside down. As briefly mentioned on their web page, the rubber bumpers are to be removed from the risers and installed to the bottom of the riser extensions."
"I just read more of the thread and see the confusion. What I think is going on, is that most people never noticed the large gap under their stock risers, so when they see it under the extensions, it confuses them. I, as many, feel that the gap is unsightly. However, HD intends for it to be there......sort of a suspension for the risers, I am sure for dampening vibration to the riders hands. So, our extensions are intended to to have slight interference (press) fit with the stock risers. Our machined in “nubs” will press into the bottom of the stock risers where the rubber bumper originally was. It’s a very tight fit, and likely will not push in by hand but will when crushed together while torquing the bolt.
Then, the bumpers install to the bottom of the extension, and the extension will sit above the triple clamp exactly as the original riser once did. Removing the bumpers and bushing cup washer will allow it all to sit lower and be more flush, for those who really want that… but it is important to consider that will increase NVH to the handle bars, and it will probably also damage the finish on the triple clamp and possible chip the powdercoat on the corner of the extensions, to have the metal/metal contact. "
"Let me add one more comment…..I do know that some Fat Bobs seem to have no gap under the factory risers. This seems to be an exception, as all of them that I have personally seen do.. but a couple users have shown me that they did not. Without having one of those bikes here at the shop, it is impossible for me to know why they do not. Possibilities could be: missing a part during factory assembly, shorter bushing sleeves, deeper bumper recess… who knows! Maybe it’s production timeline thing.. like perhaps earlier Fat Bob didn’t have as much dampening and due to NVH they decided to add more??"
Old Mar 2, 2020 | 06:08 PM
  #732
MMNCS(SS)'s Avatar
MMNCS(SS)
Nice to hear from CJM on this, thanks for reaching out to them on this.
Old Mar 2, 2020 | 06:56 PM
  #733
Norcalslinger's Avatar
Norcalslinger
Thanks for reaching out to CJM Modular. I guess I’ll have to recheck my torque or maybe purchase new rubber bumpers to get more of a gap. That being said I haven’t noticed any massive increase in the handle bar vibration. Dumb question what doe NVH stand for?
Old Mar 2, 2020 | 07:39 PM
  #734
MMNCS(SS)'s Avatar
MMNCS(SS)
NVH is Noise, Vibration, and Harshness. Probably fine with no gap if you dont notice a difference.
Old Mar 2, 2020 | 09:31 PM
  #735
Norcalslinger
Originally Posted by MoneyFor
Hello boys and girls,
I assume you know that when you quote someone, you can remove certain parts of text and images, then we don't always have to see the same pictures over and over again
Nope. Didn’t know that. Care to share so I don’t have to go searching how to.
Old Mar 2, 2020 | 09:37 PM
  #736
mrjoede's Avatar
mrjoede
how well do you like your cafe fairing and how much air does it deflect, thanks joe
Old Mar 3, 2020 | 12:40 AM
  #737
MoneyFor's Avatar
MoneyFor
Originally Posted by Norcalslinger
Nope. Didn’t know that. Care to share so I .......... to go _____ ing how to.
It's nothing to it, like I take your post as an example, ( see in the quote ) just click/mark the picture or text that you want to delete as you do with a normal text and hit the delete button, same for add some text.
Old Mar 3, 2020 | 09:15 AM
  #738
Bowhunter8607's Avatar
Bowhunter8607
You're not stupid but I was about to say you have them installed upside down until I saw this post. Mine never sat fully flush due to the rubber "bumpers" or isolators or whatever they are called but the gap wasn't as bad as shown in the pic above. I didn't want to remove the bunpers so I never got the more flush look.
The only way I could reduce the gap to be about the same as the stock gap was to remove the top washer on the riser bushings as mentioned above in CJ's reaponse. It never bothered me none.
Old Mar 10, 2020 | 09:34 AM
  #739
fatbob_J's Avatar
fatbob_J
3rd Gear
Anyone know of a new fairing for FXFBS? I have the DougZ, but would really like something bigger like the Russ Weirmont ... Wernymont... Weimaraner ... errr
I am NOT changing out the headlight.
Old Mar 10, 2020 | 12:32 PM
  #740
Brayden's Avatar
Brayden
Don’t know what dougz you have but doug is coming out with the SixUp windscreen attachment for the spartan mini
