2018+ Softail Models Breakout
The Everything Fat Bob Thread
Old Mar 14, 2020 | 05:29 PM
  #751
2020 Fat Bob's Avatar
2020 Fat Bob
Sometimes when coming to a sudden stop, I have no choice but to shift multiple gears with one pull of the clutch.
If I attempt to downshift from 4th to 3rd because traffic is slowing down, I won't release the clutch until I feel the gear shift, which takes multiple tries 90% of the time.
I have the same problem either way.
Old Mar 14, 2020 | 05:35 PM
  #752
Dan D.'s Avatar
Dan D.
I've had that happen before... You hit down a few, but it never downshifts. Then you think you're in first, and you're still in third it fourth.
I think it will go away, or your technique with improve with time. I know you've already had one, but it sounds like you're just riding poorly (no offense).
You can always let out the clutch, then do it again.. it should work then.
Old Mar 14, 2020 | 10:16 PM
  #753
2020 Fat Bob
Has anyone installed one of the 2 S&S EPA-compliant exhausts on a Fat Bob?
Both the S&S SuperStreet 2-1 exhaust and the S&S Grand National 2-2 exhaust have catalytic converters in them which make them EPA-compliant.
Any aftermarket exhaust other than a Screamin' Eagle installed by a Harley-certified dealership mechanic within 60-days of purchase will void your warranty. Your VIN will be locked forever if a Harley mechanic plugs your ECM into their Digital Technician II software and it detects changes from an aftermarket electronic fuel injection tuner.
My local dealership tells me that these S&S full exhausts, like many slip-ons, are made so as not to require a dyno, an EFI remap, or a Screamin' Eagle Pro Street Tuner.
I had wanted to install a TBR 2-1 exhaust, but after hearing this, I think it would make more sense to install the S&S 2-1 (no dyno expense, no Screamin' Eagle Pro Street Tuner, & it has a catalytic converter in them). Just curious to see if anyone has experience with these exhausts (the SuperStreet 2-1, in particular).
Old Mar 18, 2020 | 10:54 AM
  #754
MoneyFor's Avatar
MoneyFor
This is al so a Fat Bob, called BT-03 created by Blacktrack Motors from Luxembourg.
Old Mar 18, 2020 | 11:13 AM
  #755
LOW&GO72's Avatar
LOW&GO72
Default Fatbob..?
Ok, exactly what is it that is a FATBOB...?
Old Mar 18, 2020 | 11:18 AM
  #756
MoneyFor's Avatar
MoneyFor
It still has "thick" tires , ...... I often think the same with those high T-bars or sissy bars on an FXFB(S)
Old Mar 18, 2020 | 02:50 PM
  #757
SVT-RapTor's Avatar
SVT-RapTor
Somewhere under there is a Fat Bob.
Old Mar 19, 2020 | 12:15 PM
  #758
18FXFBS's Avatar
18FXFBS
Gauges
Old Mar 19, 2020 | 12:49 PM
  #759
MoneyFor's Avatar
MoneyFor
Originally Posted by 18FXFBS
Gauges
yes , now the 49 other parables.
Old Mar 21, 2020 | 10:42 AM
  #760
Olive oil 2.0's Avatar
Olive oil 2.0
I've got the S&S Grand National 2 into 2 full system that has NO cats. They make both with and without cats versions. Really like the look and it sits high enough where scraping is not an issue. I would think ANY full system woul need at least a tuner to get the most out of it.
