2018+ Softail Models Breakout
The 2018+ Everything Breakout Thread
Old Oct 13, 2021 | 09:04 PM
  #91
txphatboy's Avatar
txphatboy
Originally Posted by KStewart
2020 Breakout, S&S 128 big bore kit, 10:75 comp, 64mm TB, 5.5 inj., Red Shift 468 cam,
Don’t see too many softail 128” with 2-2 exhaust. What exhaust is it and do you have a Dyno sheet? Curious how 2-2 affected power?
Old Oct 20, 2021 | 09:23 PM
  #92
brandon c's Avatar
brandon c
3rd Gear
Default 2018 breakout brake and turn signal wiring colors
2018 breakout
Old Oct 20, 2021 | 09:25 PM
  #93
brandon c's Avatar
brandon c
3rd Gear
does anybody know which color wires go to the brake and turn signals?. i have black blue and violet or purple
Old Oct 20, 2021 | 09:30 PM
  #94
alex0730's Avatar
alex0730
You have run / turn signals in the rear. (2 plugs… left side and right side)
black wire = ground
purple wire = turn signal
blue wire = run signal
Old Oct 20, 2021 | 10:40 PM
  #95
brandon c's Avatar
brandon c
3rd Gear
black wire = ground
Ok? So what is the run wire for. ( Blue wire )
Old Oct 20, 2021 | 10:45 PM
  #96
alex0730's Avatar
alex0730
thats the light that stays on all the time. Then other one (purple) is what makes the light flash / blink.
Old Oct 20, 2021 | 10:49 PM
  #97
brandon c's Avatar
brandon c
3rd Gear
So blue is constant and purple is blinker. What about the brake light?
Sorry man. I'm not electrical savvy
Old Oct 20, 2021 | 10:59 PM
  #98
alex0730's Avatar
alex0730
you will need a converter in order to run the light as run / brake / blinker.
custom dynamics makes them. I ordered a pair on amazon.
https://www.customdynamics.com/trufl...dual-converter
Old Oct 20, 2021 | 11:03 PM
  #99
brandon c's Avatar
brandon c
3rd Gear
Thank u very much
Old Oct 24, 2021 | 02:00 PM
  #100
jfl330's Avatar
jfl330
Default Added backrest....
