2018+ Softail Models Breakout
Heritage shifter
Old Aug 12, 2020 | 07:00 PM
LaRSin's Avatar
LaRSin
Originally Posted by Mart
Im thinking about trying this to see if helps me find neutral. Scratching my head a bit. Not obvious why you need to undo those two screws you've arrowed. Do you have to take that lower casting off because otherwise there's insufficient clearance to slide the spline out before it touches the primary case?
I had to loosen them enough to fit the new spline in , As the new one is longer,,
Old Aug 13, 2020 | 02:56 AM
Mart's Avatar
Mart
Originally Posted by Hulkss
If neutral is hard to find, your clutch is dragging a little. Harley just changed the release ramps to open the clutch more and reduce the drag. See attachment.
Original M8 Softail ramps are 19 degrees.
Thanks. Yes I saw that posted on another thread. I registered the problem with my dealer and we are "monitoring" it... Don't want to highjack this topic. I think the answer to my question is the lower bracket needs loosening, so there's play in there to have enough room to slide the new, longer spline in.
Whtwolf14
Apr 22, 2017 04:00 PM
bkrhoades
Apr 27, 2014 05:01 PM
stevieg
Feb 22, 2012 07:58 PM
NitroBerserker
May 30, 2009 08:39 PM
frostydawg69
Oct 14, 2008 09:10 AM
