2018+ Softail Models Breakout
Stage 1 to Stage 2?
Old Sep 26, 2020 | 01:55 PM
Ric Kaysen's Avatar
Ric Kaysen
Default Stage 1 to Stage 2?
20 LRS... Added V&H slip ons, had the dealer do a stage one tune and the bike goes like a scalded cat the way it is. Had a torque cam in my old Softail and it really hauled but trying to justify the cost of a stage 2 cam and looking for opinions.
Old Sep 26, 2020 | 02:01 PM
touchdown's Avatar
touchdown
If your happy do nothing
Old Sep 26, 2020 | 02:59 PM
Hulkss's Avatar
Hulkss
I think a Stage II cam is totally worth it, however, do this test first. Try to use full throttle frequently in the rpm range where you like to ride (be safe). If you find your bike to be weak, then get a cam. Otherwise leave it alone.
My bike failed this test as Stage 1, passes as Stage II. Get a cam with a torque peak where you ride.
Old Sep 26, 2020 | 08:00 PM
P51Driver's Avatar
P51Driver
I agree with the other guys who previously posted. My experience with a stage 2 upgrade on my 2018 Lowrider is it was worth doing. My 107 M8 with stage 1 was ok but lacking on the lower end, which is what I expected. But when I installed the Wood 22X torque cam it really woke the bike up in the rpm range that I typically ride in. In fact I found myself riding quite a bit harder after I installed the cam. I don't like beating on my bike, but after I installed the cam I just couldn't help myself.
Old Sep 27, 2020 | 08:13 AM
GalvTexGuy's Avatar
GalvTexGuy
Read post #3:
https://www.hdforums.com/forum/2018-...-uogrades.html
Old Sep 29, 2020 | 03:28 PM
Tampa Fatboy's Avatar
Tampa Fatboy
My advice, look aat the date code on the right hand down tube decal. Anything before June '19 has the old faulty oil pumps. They were revised 3-4 times since the M8 come out. Finally they designed a new better oil pump.
My stage II, I did the new oil pump out of pocket after fighting with HD over it
Old Sep 30, 2020 | 10:44 AM
Las Vegas Jim's Avatar
Las Vegas Jim
The Stage 1 upgrade is a must for all M8 bikes. But, I suggest you ride your bike for a while longer before doing the Stage 2. I waited to do the Stage 2 and determined that a suspension upgrade would improve the handling and comfort of the bike far more than a Stage 2 upgrade would. Good decision.
Old Sep 30, 2020 | 04:57 PM
Tampa Fatboy
huh? suspension? Really? Stage 2 wakes that scoot up if done properly.
Old Sep 30, 2020 | 07:44 PM
Las Vegas Jim
Did the same test; same result.
Ralph Lin
Milwaukee Eight (M8)
46
Jun 8, 2020 07:37 PM
traumatyzd traumatyzd
17
Aug 27, 2019 11:03 AM
big-gun
Engine Mechanical Topics
Sep 28, 2014 09:12 AM
cpita
Nov 30, 2013 05:28 AM
bdavis
May 3, 2007 03:15 PM
