2018+ Softail Models Breakout
Battery Tender Cable Routing - Heritage Classic
Old Feb 15, 2021 | 09:20 PM
Beemertrash's Avatar
Beemertrash
Default Battery Tender Cable Routing - Heritage Classic
Where is everyone routing their tender cable ? I have not found a good spot yet.
Old Feb 16, 2021 | 06:11 AM
sandrooney's Avatar
sandrooney
Should already be there. Mine is on the left side coming out from under the side cover. 2018 Heritage.
Old Feb 16, 2021 | 07:55 AM
rtbuck89's Avatar
rtbuck89
I have nothing to offer except I just bought a used road king, and it has THREE different charging ports connected to the battery! One coming out the front under the tank, and one on each side. There's an idea for you
Old Feb 16, 2021 | 08:23 AM
MCSarge's Avatar
MCSarge
Someone was probably using the ports to power heated gear. Not sure why else you would need three.....LOL
Old Feb 16, 2021 | 09:55 AM
Beemertrash
I think I worded my question wrong, I found the charger cable behind the left side cover. I was wondering where people were routing the cable so as not to have to remove the side cover when you use it. Thanks.
Old Feb 16, 2021 | 10:11 AM
aecs's Avatar
aecs
Mine just hangs below.
Old Feb 16, 2021 | 10:28 AM
Lee F.'s Avatar
Lee F.
Mine came sticking out on the front of the cover and kind of laying on the lower engine case. If you push it back under when not in use you can't notice it. Just leave it out enough so you can grab it with your fingers when you want to plug in. Works great.
Old Feb 16, 2021 | 08:53 PM
Uncle G.'s Avatar
Uncle G.
I just leave mine sitting behind the outer primary cover.
Old Feb 16, 2021 | 09:16 PM
Beemertrash
All good stuff, nice to read different ideas. This forum is bitchin'.
Old Feb 17, 2021 | 08:36 AM
tmac00333's Avatar
tmac00333
Yeah, just remember to insert the little plug that's connected to the cord, especially if it rains or whatever.
YammyBase
Feb 2, 2018 10:47 PM
Amrap
Sep 24, 2016 10:49 PM
tennheritage
Feb 21, 2015 06:40 PM
Iron lHorse
Jun 7, 2014 03:08 PM
Trucky911
Jul 28, 2012 07:06 PM
