2018+ Softail Models Breakout
Does this look right?
Old May 10, 2022 | 03:18 AM
TedMan's Avatar
TedMan
Default Does this look right?
Put my holdfast backrest and rack on for the first time and noticed that the rack is angled up. It's seated and the spools are adjusted. Take a look at these pics and tell me what you see.
Old May 10, 2022 | 04:19 AM
aviscomi's Avatar
aviscomi
It seems to look a little upward. I just ordered the same rack on Saturday, I'll make sure I take note of the angle.
Old May 10, 2022 | 04:55 AM
Doublefelix's Avatar
Doublefelix
I see an Indian.
IronAss's Avatar
IronAss
Looks slightly angled up.
I wouldn't have a problem with it if on my bike though.
It'll will keep whatever you put on there more secure against slipping off the end of the rack.
Old May 10, 2022 | 05:07 AM
Doublefelix
What seat is the Indian sporting? It looks grey/black two-tone?
Not trying to hijack. The rack looks a little canted but if it is seated, then it shouldn't be an issue. it will probably settle a little bit from use. The hold fast doesn't seem to be "overbuilt" and some flex may happen.
Old May 10, 2022 | 05:14 AM
RANGER73's Avatar
RANGER73
It will keep whatever you put on there more secure against slipping off the end of the rack.
^^^This, I agree on the "Looks angled" and esthetically it would bother me too.
But it might be intentional. Try loosening all the shelf bolts and mount bolts and leaning on it.
Never mind, When you sit on the bike the weight will drop the rear and it'll be level. Or lower the rear
Old May 10, 2022 | 06:08 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Looks like the passenger pillion is missing. Kinda hard to use the back rest with that solo seat.
Maybe loosen up the screws/bolts holding the rack to the sissy bar and see if you can adjust. Looks like it will work just fine the way it is though.
Old May 10, 2022 | 06:53 AM
mrcribbs's Avatar
mrcribbs
Mine is also angled upwards slightly.
Old May 10, 2022 | 07:42 AM
RANGER73's Avatar
RANGER73
I'll assume your kidding.
Old May 10, 2022 | 10:55 AM
TedMan's Avatar
TedMan
Corbin Wall/Gunfighter. It is a custom two-tone. I'm a Corbin fan.
Thanks all for replies. I may try to loosen the bolts and adjust, but judging by the way the brackets hold the rack onto the upright, there may not be much wiggle room. Appreciate the responses.
