Speaker advice needed
Old Jan 15, 2016 | 04:26 PM
Weeboy1's Avatar
Weeboy1
Default Speaker advice needed
Hi,
2010 ultra, not changing h/u just looking for better sound quality over stock.
Found either infin.kappa 52.9 or 62.11i locally for under $100 and under $200 respectively. Can I just swap out the stocks for either of these without an amp and expect much improvement?
After which if I decide to ad an amp I don't wish for the biggest and best just again improved over stock.
Would the rf pbr 300 or the sound stream pn4 be my starting point for barebones amp choices?
Need fm reception.
Thanks
Old Jan 15, 2016 | 04:29 PM
Weeboy1's Avatar
Weeboy1
Sorry should also mention not adding any speakers in future beyond the 2 front fairing.
Old Jan 15, 2016 | 04:31 PM
SBates08's Avatar
SBates08
In this case, being that FM is a must, and no desire to upgrade the rear speakers, I would suggest the Kappa 62.11 and the PBR 300x2. Just adding new speakers will not get you a better sound without adding an amp.
You will also need adapter rings for the 62.11 to fit.
Old Jan 15, 2016 | 06:10 PM
haze324's Avatar
haze324
+1 with Bates
Also the 62.11i are 110.00 on Amazon right now.
Old Jan 15, 2016 | 08:47 PM
Weeboy1's Avatar
Weeboy1
Thanks for the input.
thought the kappas came with adapters.
also if I get the speakers first can I still use them without the amp. (the stock H/u will drive them without issue)
$110. US that's like $225. Can. (not quite but feels like it about now)
ardakota
Audio Systems
Jan 4, 2017 01:50 PM
canible
Dec 24, 2016 02:41 PM
Tinsleytown
Audio Systems
Apr 1, 2016 05:48 AM
soberjoe
Audio Systems
17
Dec 4, 2015 09:57 AM
hdman6
Mar 25, 2012 03:02 PM
