Ground
Old Feb 6, 2016 | 09:09 AM
SBates08's Avatar
SBates08
Originally Posted by evomat
Changing amp not an option. I do not have rear pods,only fairing speakers. Do i bridge amp ? And run polks? Further down the road looking at 6x9 lid spkrs. Will probably change amp out then or an additional amp. looked at pn4, and the difference is 10 watts rms vs the st4 . both are class D . is 10 w that much difference?thx again for all information
There's a difference of 50 watts per channel at 4ohms and 125watts difference per channel at 2ohm.
If your planning future mods you'd be money ahead to switch amps now as the SS pn4.1000 will power whatever your heart desires.
Old Feb 6, 2016 | 09:13 AM
Gannicus's Avatar
Gannicus
Yeah That!
Old Feb 6, 2016 | 01:35 PM
Tailwind's Avatar
Tailwind
Originally Posted by Gannicus
Yeah That!
Gan,
Knowing that u r the ARC SME, would this type of SS stealth amp do well bridged pushing the ARC Moto 692s? RMS 250 bridged for the SS, but there are a couple of other options that are sized right for under my hood and will push from 250 RMS and up but just want to see if this amp or similar and 250RMS+ is in the wheelhouse for this speaker.
At first glance it also looks like this speaker will sit good inside the bag side mounted with maybe a very small spacer & weather stripping.
Thanks!!!!
T.
Old Feb 7, 2016 | 12:35 AM
09baggerdude's Avatar
09baggerdude
Originally Posted by Tailwind
Gan,
Thanks!!!!
T.
You could do the b2 or b52 for about the same money. I'm gonna say that 250 is overkill for the motos. ...
Old Feb 7, 2016 | 05:10 AM
Tailwind's Avatar
Tailwind
That's a damn good lead!!! I'm gonna pull the hood today and get exact measurements for what will fit on the JM amp tray next to my BT4180. Was thinking I might only have room on the tray for this 5 1/2 inch cycle sound amp but might be able to squeeze another inch out of the tray area. Might have other options under there as well.
My dragon snapped my panties pretty hard when she saw the speaks in the bottom of the bags as apparently this his "her space" so putting the amp in the bag is gonna be a tuff sell. Might eventually get an upsized tour pack from the razor for road trips and then the bags will become all mine!!!!!!!
Thanks for the lead!!! These never came up in my search for compact amps.
T.
Old Feb 7, 2016 | 07:04 AM
haze324's Avatar
haze324
T
That cycle sounds amp is rebadge of this NVX. Pretty big mark up!! A few folks have used it and AAWAV tested it and it does rated power. Could be an option bridged and I think better than the SS stealth. When you have some measurements let us know.
http://www.sonicelectronix.com/item_71775_NVX-MVPA4.html
Old Feb 7, 2016 | 09:15 AM
Bertk's Avatar
Bertk
Here you go.
CV B52: 4.02"W x 6.61"L x 1.40"H - $168
Macro 4405-0263-2: 4”W X 5-7/16”L X 1-9/16”H - $300
NVX MVPA4: 4”W X 5-7/16”L X 1-9/16”H - $150
Old Feb 7, 2016 | 05:04 PM
Tailwind's Avatar
Tailwind
Thank u BertK!!!! Never got the hood off today. Installed the speaks inside the lids today. Like it a bunch!!!!
Will provide measurement info regarding the BT4180s potential sister on the tray soon.
Thanks again for the info!!!!
T.
Old Feb 7, 2016 | 07:28 PM
Bertk's Avatar
Bertk
T.
You're welcome. What speakers did you end up installing?
Old Feb 7, 2016 | 07:50 PM
Gannicus's Avatar
Gannicus
Gan,
Thanks!!!!
T.
Not a fan of that amp. Not because it's a bad amp. But why purchase that amp when you can get the PN4.1000D for a few dollars more? The economics makes no sense. No bang for the buck. Getting back to to Moto's If you check out the Moto thread HDAUDIOMAN put 300 watts to the motos and they performed flawlessly. They love power!!
