hogtunes
Old Mar 20, 2016 | 12:27 PM
RSDUDA's Avatar
RSDUDA
Default hogtunes
I am considering upgrading my and my wife's auto system with the hogtunes amp and speaker package was wondering who has done this and it says it is plug and play no dealer program required ?
thanks for any input
Ron
Old Mar 20, 2016 | 01:17 PM
Tailwind's Avatar
Tailwind
What kind of set up are u looking at, what model and year sled, and what is the approximate price range?
Not trying to pry, but I think u will get good feedback here regarding a plug and play set up that will get you the most bang for your buck. In many many cases you can blow away the HT sound quality and reliability for equal or lesser donuts.
T.
Old Mar 20, 2016 | 01:36 PM
RSDUDA's Avatar
RSDUDA
I am looking at the Hogtunes 2 speaker and 200 amp kit for a 16 flhxs and the 4 speaker 200 amp kit for a 14 flhtk
Old Mar 20, 2016 | 02:00 PM
Tailwind's Avatar
Tailwind
U have cost for each handy?
T
Old Mar 20, 2016 | 02:10 PM
RSDUDA's Avatar
RSDUDA
$402 and $654
Old Mar 20, 2016 | 02:31 PM
Gannicus's Avatar
Gannicus
RS -
The REV 200 RM is the amp you seek from Hog Tunes. 2 channel amp. Cost $329.95 for the amp alone. The REV 200 SG Kit-RM with the hog tune speakers is $429.95. The amp specs are very deceiving. You're actually looking at approximately 50 watts per channel.
You can get a much better system for the money for the SG. Same thing with the limited. No dealer program necessary is a marketing strategy.
Old Mar 20, 2016 | 02:33 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
There may be better or less expensive setups out there. That said, I have a 6 speaker Hogtunes system (Fairing, lowers, tweeter) on my Streetglide and am very happy with it.
Old Mar 20, 2016 | 02:41 PM
RSDUDA's Avatar
RSDUDA
Default Hogtunes
The two systems we are looking at are half the cost of the Harley set up , is it true they don't require dealer program?
Old Mar 20, 2016 | 02:51 PM
haze324's Avatar
haze324
The fact they don't need dealer programming should steer you clear of this set up. The factory HU signal is programmed/set with a frequency curve to compliment the stock speakers without an amplifier. When you amplify that "curved" signal with sufficient power what you get is a distorted sound because it is not a flat frequency signal like what comes out of any radio you've messed with before; think the treble and bass (or Equalizer) in your car. So the dealer "flash" is to set the radio to an amp setting where there is a flat signal. Companies like Bikentronics sell converters that will flatten the signal.
So if a company says their system is plug and play and you don't need a flash it's because the amplifier is not sending enough power to cause distortion and that means it's also not enough power to enjoy your tunes at speed.
If you are going to make the investment I would steer clear of the Hogtunes products. For a tad more the closest thing to plug and play without needing dealer flash is a Biketronics system and it's leagues better.
Old Mar 20, 2016 | 05:51 PM
matt76cmich's Avatar
matt76cmich
Default hogtunes
For a 2 speaker comparison (not familiar with Hogtunes packages).
My first setup on my 15' SGS was a Cerwin Vega B2 with Arc Audio Moto 602 6.5" speakers with a PAC SNI-35 w/dealer flash which ran me about $420.
With some of the sponsor vendors (LL247) you can get the 602's cheaper than I did which would offset the price of the new Biketronics BT355 which you will not need a flash. You can also go with the Cerwin Vega B52 which has 50 more watts than the B2.
I have switched to a BT355 and an amp with comparable power to a B52 and the sound is a lot better. (check our Bunkers vids of his Rockford amp bridged to the 602's to give you an idea).
Just something to think about and give you another option.
