Diamond amp help
Old Dec 24, 2016 | 01:55 AM
BaggerAudioLab's Avatar
BaggerAudioLab
You need both RCA plugged in.
My guess on the resistor is so the radio sees a load if you are using high level inputs. If you are using line levelers you don't need it.
Old Dec 24, 2016 | 02:03 AM
Tstreet15's Avatar
Tstreet15
I can turn the amp to about 21 one the 1000htz test and listen to music it dont sound distorted just loud like it should. But little blues lite flashes.
Old Dec 24, 2016 | 06:21 AM
slyedog's Avatar
slyedog
unless your clip light is getting red like has been said half a dozen times already you are fine. Walk away. Keep head unit under 17 for volume max. But asking here, asking multiple places on Facebook will as well just gets your more confused. Pick your place of advice and stick with it please. Makes it hard to want to help someone that is asking all over the place for trivial settings. Not being a dick, just saving us all less confusion.
Old Dec 24, 2016 | 08:43 AM
BlackPearl#1's Avatar
BlackPearl#1
No worries with blue light. That simple, period, end of story. RED=BAD.
Kris
Old Dec 24, 2016 | 09:03 AM
matt76cmich's Avatar
matt76cmich
Ok, again. In my experience with the hxm 800.2 my dd-1 and DMM were useless. I used the clipping light on the amp while listening to a bass heavy rap song and then some metal music. I turned the gain up till I was getting blue light with hints of red and backed it off just enough to the point i was barely seeing any red, more less blue with a hint of red.
Now I'm not sure what's going on with the compasiters you're talking about, but trust the clipping light on the amp.
If i only trusted my dd-1 and DMM I would have been clipping at less than a quarter turn of the gain and it was quieter than stock.
Old Dec 24, 2016 | 09:37 AM
Tstreet15's Avatar
Tstreet15
I could turn it up all the way and not get any red flashing. The light would just stay on at a brighter blue.
Thats what I am confused with i dont get any red flashing.
On mine the Blue light just gets brighter to the point it stays light.
If i go by the clip light I could only get a little over a 1/4 turn. It didnt sound much better then stock to.
Old Dec 24, 2016 | 10:05 AM
matt76cmich
Ok, hmm. If you can post a picture of these compasitors. Not sure what's goin on.
Old Dec 24, 2016 | 11:08 AM
Tstreet15's Avatar
Tstreet15
Old Dec 24, 2016 | 11:13 AM
BaggerAudioLab
Ok I'm going to take some guesses here.
1. The gains are going that high up without showing red distortion because the LL input voltage is so low. It's called an "input" gain. The less the input the higher the gain. If it sounds good, set it by ear and forget about the stupid light.
2. I'm pretty sure I read a while back that the rushmore HU's require a load or the shut off. No load = the radio thinks no speakers are plugged in (speakers provide a load, an amp doesn't). So diamond is giving you resistors to provide a load to the radio in the even you were not using some type of converter to use RCA's. That's my guess, if I'm remembering that correctly.
Old Dec 24, 2016 | 02:07 PM
Makdaddy's Avatar
Makdaddy
Nvrmnd
HogPilot54
Audio Systems
Jul 23, 2017 11:05 AM
rnl_1200C
Jan 4, 2012 09:45 AM
South Jersey Scooter Trash
May 30, 2011 11:09 AM
Grrrl
Mar 5, 2010 12:04 PM
dynamike74
May 19, 2008 04:08 PM
