My BAL designed install
Old Jan 26, 2017 | 01:27 PM
Kave Dweller's Avatar
Kave Dweller
Still waiting on my fairing to come back from paint!!!!!
Old Jan 26, 2017 | 06:57 PM
SgtMic's Avatar
SgtMic
Originally Posted by Tailwind
U talking about the long bolt hole that goes thru the inner fairing?
T
That one. The brake side lined up just fine. The clutch side was off just a hair.
BT really does need to predrill the extra holes.
Old Jan 26, 2017 | 07:52 PM
Bertk's Avatar
Bertk
I mentioned it to Mike at BT the other day.
Old Jan 26, 2017 | 07:55 PM
Bertk's Avatar
Bertk
Originally Posted by MMXIWG
How many bolts per bracket? Looks like one from the pictures.
One bolt per bracket. The spacers can also be found at ace hardware also.
Old Jan 26, 2017 | 08:42 PM
WestTexasRanger's Avatar
WestTexasRanger
I was just about to finish my installation when I ran across Bertk's original post about stiffening up the inner fairing, so I actually disassembled everything, in order to make this modification.
I used the original socket head screw from the pods in the hole, adjusting it in & out until it just touched the BT bracket. No need to bolt the bracket back in place for this, just put a few screw drivers though the mounting holes to get everything lined up. I then moved the bracket out of the way, put some clay-bar on the bracket (in the area where the new hole is going to be located), realigned the bracket, then pushed it into place, against the socket head screw. The result was a perfect imprint of where to drill the new hole.
The mount in the fairing and socket head screw are not perpendicular to the BT bracket. To compensate for this, I cut the nylon spacer at an angle and used the left-over as a wedge on the opposite side.
In addition to the additional mounting hole in the bracket, it would be nice if Biketronics included a front & back spacer of some sort and a 1 1/2" bolt for each bracket. That's not much to ask, especially considering the cost of the brackets.
Old Jan 26, 2017 | 08:48 PM
Springerfan's Avatar
Springerfan
Thanks for the tips WTR, I am just behind you so this is extremely helpful. SF
Old Jan 26, 2017 | 08:54 PM
WestTexasRanger
You're Welcome.
I just started a new thread about my finished install. You might want to check it out.
Old Feb 10, 2017 | 09:58 PM
SgtMic's Avatar
SgtMic
Added in the new amp so of course things had to be rewired. LOL
Attached Thumbnails My BAL designed install-20170210_192251.jpg   My BAL designed install-20170210_192305.jpg   My BAL designed install-20170210_192312_burst01.jpg   My BAL designed install-20170210_192320.jpg
Timothy Rau
Audio Systems
Jul 3, 2019 03:55 PM
SSpeeDEMONSS
Audio Systems
Feb 26, 2018 02:04 PM
whataboutbob
Audio Systems
Jul 27, 2017 01:54 PM
Kawickrice
Audio Systems
17
Jul 11, 2017 03:16 PM
dapster
Audio Systems
Mar 24, 2015 04:14 PM
