Flat Response Boom Flash
Old Oct 7, 2017 | 10:19 AM
  #31
ROCKOUT Rocker Products
Sponsor
The flash in my bike is as described above... 8 speakers (even tho I have only 4) Amps.... no, amps on.... yes (makes no sense). It's the old MOCO flash from 2015. I have the full BT 4180 setup, 7.1 front and MM651 rear, bike sounds awesome. I have software version 1.18.3. Tried others over the years, something always didn't work.... fade, auto volume... something. On mine everything works as it should. The EQ is 00_OFF (ON).BIN
I tried the BT line levelers out or curiosity, made everything worse... washed out sounding. I'm using the old PAC SNI-35 line in converters.
Now all that said.... it's kind of a curse in a way. If I ever have the dealer do anything to my bike I have to stand guard over the update port. I can't use the new bluetooth wireless headset system because it requires a dealer flash. If someone could guarantee I could retain the same sound with a new flash I'd be all over it. To date the user reports aren't good. (not talking DSP setups here, just flashes) If someone has gone from my flash to the JM flash I'd sure like to hear their results
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Oct 7, 2017 | 12:01 PM
  #32
JMJOHN's Avatar
JMJOHN
Sponsor
When using the Diag-4-bike you do exactly the same things as with the Techno-research digital technician ,,,,,
FIRST: 4-speakers, upper-fairing, rear-pods, no-amp ,,,,,
SECOND: Amp#1 "YES" ,,,,, (instead of NO)
THIRD: Amp#2 "YES" ,,,,,,, (instead of NO)
that simple ,,,,,
for those of you who want to send your Harley Infotainment radio (Including CVO radios) to J&M for this flash, we charge $75 for the flash service, AND shipping back to you via Fed Ex ground is no/charge ,,,,,,
J&M Corporation, 1415 S. Cherry Ave. Tucson AZ 85713 ,,,,,, 1-800-358-0881 ,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Oct 7, 2017 | 01:04 PM
  #33
Kawickrice's Avatar
Kawickrice
I have a 17 Limited that has whatever flash they used when it was born. Since I have 4 speakers no amp (from factory) am I good to go? John says first is 4 speaks no amp, Is that not what I have? Alex says 8 speaks 2 amps does the trick. Since I am still learning this stuff I am totally confused about flashes. I do have a BT355. What should I do?
  #34
Kawickrice's Avatar
Kawickrice
Old Oct 7, 2017 | 02:27 PM
  #35
Respect's Avatar
Respect
Have you already installed stuff? If so how does it Sound? My own ride is a 17 Ultra Limited. Overall there was lots of room for improvement when I started but I resisted changing the speaker config. I'm going to finish it then try Haze's settings. All other things being equal i should be able to pick apart any differences from the change.
Old Oct 7, 2017 | 02:37 PM
  #36
Tailwind's Avatar
Tailwind
Originally Posted by JMJOHN
if all you have to “bitch” about is J&M charging $75 for the proper flash for your Harley radio, you are missing the whole point ,,,,
Not bitching about the $75 bucks at all. Bitching about the Custom JM snake oil bullshix attached to the $75 bucks.
GO AWAY!!!!!!!!! Or at least post up ur perpetual over-the-top sale pitch garbage in the proper vendor section of this forum.
Moderators, where u be?????
T.
Old Oct 7, 2017 | 03:17 PM
  #37
JMJOHN's Avatar
JMJOHN
Sponsor
Kawickrice ,,,,,,
all J&M ROKKER and Performance series amplifier kits for 2014-2018 Harleys are set up for the STOCK HARLEY FLASH just the way your bike came from the factory ,,,,,
so are most other brand amplifier kits like believe like Biketronics, etc ,,,, stock Harley flash, which simply means that the flash on your Harley radio came from the factory as either (Two-speakers, Upper-Fairing No-Amp) OR (Four-Speakers, Upper-Fairing, Rear-Pods, N0-Amp) ,,,,,
AND your Harley Dealer CAN flash the radio to either one of the speaker configurations above, using their Harley digital technician ,,,,,, either one of these stock flash speaker/amp configurations can also be done with the Techno-research OR the Diag-4-bike digital technicians ,,,,
it is ONLY when you want to fine tune your audio system performance BEYOND the stock flash, with hi-performance components like you will find with the J&M ROKKER series, that you want the special radio FLASH configurations that we have been talking about on this thread (((that the Harley dealer cannot perform)) ,,,,,
an example of this would be the J&M ROKKER Stage4 stuff shown here https://www.jmcorp.com/SeeProducts.asp?PF=57 ,,,,
Old Oct 7, 2017 | 06:14 PM
  #38
Sponsor
that simple ,,,,,
To be clear....
You're saying after doing this my bike will sound exactly as it does now? If so I'm in.
Also, what happens then if I get the bike flashed to work with the new HD bluetooth headsets?
Sorry to be so dense.
Old Oct 7, 2017 | 07:42 PM
  #39
cpbedor's Avatar
cpbedor
Originally Posted by matt76cmich
That quote looks appropriate here i think.
It would look a lot better coming from a moderator who was VERY SWIFT to jump on Alex for posting but has mysteriously been completely absent since this troll returned to the forum. I guess rules don’t apply to everyone.
Old Oct 7, 2017 | 08:24 PM
  #40
JMJOHN's Avatar
JMJOHN
Sponsor
ROCKOUT ,,,,
FLASHING the radio for the new Harley WHIM (Wireless headset module) will NOT alter or stop you from altering the speaker/amp flash configurations for the external speakers as is shown in this thread ,,,,,,
they are two completely different operations ,,,,,
the GOOD NEWS is if you DO get the new Harley WHIM, you are NOT married to the Harley Boom/Sena Bluetooth headsets ,,, the J&M high performance Bluetooth headsets will also work ,,,,,
However ,,, in about 4 weeks J&M will release it's own dual module Bluetooth dongle that duplicates the features of the new Harley WHIM dongle, but with considerably better audio performance to the Bluetooth headsets than the Harley/Sena WHIM,,,,,,
