Biketronics line levelers
Old Jun 8, 2018 | 02:05 AM
Trixter's Avatar
Trixter
Default Biketronics line levelers
My bike is a 14 street glide and I'm wondering if because it only had two front speakers will the biketronics breakout connector work? Or do I have to have the radio flashed to four speakers. And if I have the stereo flashed do I really need the line levelers. I know this has probably been beaten to death but this is the last piece of my stereo puzzle aside from mounting my soundstream pn4,1000 amp thanks in advance.
Old Jun 8, 2018 | 04:30 AM
USAproud's Avatar
USAproud
If you want to be able to fade front to rear you need the flash and breakout harness. If your only running 2 speakers in fairing you only need 1 lineleveler.
Old Jun 8, 2018 | 05:47 AM
SBates08's Avatar
SBates08
I don't think the breakout harness is needed on the Street Glides. You'll have to run new speaker wire to the rear if your going to put speakers back there or in the lowers for that matter. All the HD flash does is enables the rear speaker outputs in the HU. It doesn't take the place of the Line Leveler.
Old Jun 9, 2018 | 01:26 AM
Trixter's Avatar
Trixter
Ok I understand that if I want to run rear speakers I near to run wires back there. I just mostly wondering if the rear channel needed to be turned on in the head unit. Thanks for the replies
Old Jun 9, 2018 | 09:55 AM
SBates08's Avatar
SBates08
Only if you want to have fade. Otherwise you can use a Y splitter.
johnsonnd06
Audio Systems
15
Jul 6, 2017 10:28 AM
Fire4Effect
Audio Systems
19
May 11, 2013 02:38 PM
TheLazyC
Audio Systems
May 6, 2013 06:00 PM
Fire4Effect
Audio Systems
Apr 25, 2013 07:29 AM
ironglass
Jun 22, 2009 08:43 AM
