Prv 8s
Old Sep 24, 2018 | 04:46 PM
azmaniac's Avatar
azmaniac
Default Prv 8s
If anyone cares to share...right now trying out some prv8mr500ndy4 in my speed by design lids and Tourpack...I know of course it varies on wattage etc but WHAT ARE YOU GUYS CROSSING EM OVER AT MORE/LESS...I'm running off a jl audio 600/6 right now...NOT BRIDGED...sound pretty damn good but wondering if I should bridge em and drop em to a 2 ohm load etc
Old Sep 24, 2018 | 05:01 PM
SBates08's Avatar
SBates08
You know you can't bridge that amp at 2ohms!!!
Old Sep 24, 2018 | 06:45 PM
azmaniac's Avatar
azmaniac
Ok I was just going by posted specs
Old Sep 24, 2018 | 06:56 PM
haze324's Avatar
haze324
That’s 2ohm stereo. It says right below only 4ohm bridged.
Old Sep 24, 2018 | 06:57 PM
USAproud's Avatar
USAproud
You can bridge 4 ohm speakers but not 2 ohm speakers with that amp. If you have 8 ohm speakers you have other wiring options as well. If it sounds good to you why mess with it?
Old Sep 24, 2018 | 07:09 PM
azmaniac's Avatar
azmaniac
🤔 hmmm
Old Sep 24, 2018 | 07:10 PM
azmaniac's Avatar
azmaniac
Why mess with it that's the silliest question I've ever heard Josh ,😂🤣😅 we both know the answer to that....cause we always want a lil bit more and a lil bit better!!!
Old Sep 24, 2018 | 07:14 PM
USAproud's Avatar
USAproud
Very true. I cant argue with that lol. Maybe some of the smart guys can chime in and give you better wiring options. I have an idea but will wait for other responses.
Old Sep 24, 2018 | 07:17 PM
azmaniac's Avatar
azmaniac
I never put enough thought into it
jl audio 600/6
Channels 1&2 dd b3 horns
Channels 3&4 6MR500-NDY-8 ran at a 4 ohm load
Channels 5&6 8MR500-ndy-4 ran at 4 ohm load
Every thing I just put I have doubled...ran the exact same way make sense....2 amps 4 6.5 speakers 4 8 speakers 4 horns
Old Sep 24, 2018 | 07:24 PM
USAproud's Avatar
USAproud
Add a 4 channel micro amp for the horns in the fairing.
Run the 6.5" 8ohm speakers bridged parallel to channels 1 and 2 from each amp. That gives them close to 100 watts each. Then bridge the 8" 4 ohm speakers to 3,4,5&6 on each amp. just doubled your power by adding a small amp.
Wait for someone smarter than me to confirm
