Why did I wait
Old Feb 12, 2020 | 09:09 AM
Fireball Jack's Avatar
Fireball Jack
Default Why did I wait
Why did I wait so long to ditch the stupid T27 Torx bolts in the fairing. I replaced them with 1/4 -20x1/2 Allen head bolts with a flat washer. This makes getting the two lower fairing bolts so easy on a batwing.
Old Feb 12, 2020 | 10:01 AM
yooperhog's Avatar
yooperhog
Gotta agree
Ive swapped alot of factory bolts out to something more manageable
Old Feb 12, 2020 | 03:49 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
That sounds like a good idea Jack. I'd just be happy to be able to find some new T27 screws at a reasonable price, I have gotten used to them, especially since I have them on two different bikes.
I will mention something that made the two lower screws a lot easier to install though. The last time I had the chrome cover off that goes beneath the headlight I cleaned it front and back and waxed it front an back also. Having that bright shiny surface to look at while trying to put the lower screws in makes it a lot easier to see down there.
Old Feb 12, 2020 | 04:59 PM
Babyboy's Avatar
Babyboy
I am assuming that you guys are on the 13 and down batwings. The easiest way I have found when removing the fairing is to leave the lower 2 bastard screws installed and tight loosen the 2 upper screws holding the roadlights/turn signal brackets and remove the 2 lower screws placing the assembly on the covered fender. Slightly pry the lower chrome piece over the plastic and the fairing and chrome piece will come off as one.
No more crawling around ,shifting the bars left and right trying to get to those 2 bastard screws.
Old Feb 12, 2020 | 09:44 PM
wfowill's Avatar
wfowill
​​​​​​Why didn't I ever think of that!
Old Feb 13, 2020 | 09:08 AM
cshocker's Avatar
cshocker
Again, another being short advantage: those lower ones are eye level for me!
Old Feb 13, 2020 | 10:01 AM
mrmagloo's Avatar
mrmagloo
I've always just used a bit of electrical tape on the T27 driver to hold the screw firmly until I can get a few threads started. Then yank off the tape, and tighten it up. The way out, I've never had an issue grabbing them.
Old Feb 13, 2020 | 11:11 AM
Babyboy's Avatar
Babyboy
Having kielbasa fingers attached to clubs for hands makes it a little difficult to get into some tight areas small tight areas 😂😂 so you have to find an easier way.
gunslingersnation
Audio Systems
17
May 16, 2019 02:37 PM
shekmark
Mar 23, 2016 02:23 PM
Tailwind
Audio Systems
Dec 26, 2015 10:38 AM
aroacha5446
May 29, 2010 12:32 PM
thomasbynum
Apr 13, 2010 09:13 PM
