‘18 Ultra Classic help please
1. Stinger amp or equivalant
2. MMats in fairing are good and will fit in fairing pods without issue. Just have to zip off the locating pin on face of pod
3. Mmats will not fit in tour pack pods without adapters and even then it's a little bit of work
4. PRV 6MB250 fit in tour pack pods and drop right in as do these https://www.crutchfield.com/p_20646C...-46CSC674.html
5. Metra ST-AK8 wiring kit for power, ground, and remote for the amp. Also comes with a nice piece of velcro for securing amp to factory rack above radio
6. HD fairing power adapter for remote power to signal amp to turn on https://www.harley-davidson.com/us/e...ess/p/69200921
7. Some good 16 gauge speaker wire to run to the speaker pods
8. BT355 (Breakout not needed, just push fade all the way to the front so it sends all the signal of head unit to the front speaker connectors)
9. A set of Stinger 4000 1.5 foot RCA cable to go between your BT355 and amp
Solder or butt connectors, some female spade connectors, TESA tape for wrapping connections, heat shrink, and some Tech flex to use as a protector for speaker wires going back to pods and you should be in business.
Don't tie into existing speaker wires. Just run new ones. Put some heat shrink over the stock connections in the tour pack pods to protect them.
Metra kit comes with speaker wire for front.
The BT355 will hook into your stock speaker plugs and then the rca end will connect to your stinger RCA and then into the amp.
Tech flex is a woven fiber wrap. Think of a Chinese finger trap. Much nicer than plastic loom.
