Line Levelers
Old Apr 25, 2021 | 01:53 PM
sbeamer's Avatar
sbeamer
Question Line Levelers
If you have an amp that is adjustable, do you still need to use line levelers? And, if you do, Who makes the best ones today?
Old Apr 25, 2021 | 02:38 PM
travelingypsye's Avatar
travelingypsye
The LL reduce the drastic EQ signal coming from the head unit. To reduce that signal you either have the HU flashed, get a dsp, or use a line leveler. At one time the LL was about the only way to reduce that drastic eq curve. Today there are plenty of people/shops that have the capability to flash your hu and usually cheaper than buying a LL. I highly suggest getting the hu flashed and using a line converter to change the high level input (speaker wire) to low level input (rca connectors) so you can hook it up to your amp.
Old Apr 26, 2021 | 09:45 AM
mikes300's Avatar
mikes300
get your Hu flashed, you dont need them anymore
Old Apr 26, 2021 | 11:53 AM
maxxym's Avatar
maxxym
How are you suppose to hook up the wires coming out of the HU to the amp without LL then?
Old Apr 26, 2021 | 12:45 PM
SBates08's Avatar
SBates08
There's a difference between Line Levelers and Line Out Convertors.
Old Apr 26, 2021 | 01:16 PM
maxxym's Avatar
maxxym
Well...****...don’t mind me...I am just passing by... lol
Old Apr 26, 2021 | 01:52 PM
travelingypsye
After flashed use this to convert your high output( speaker wire) to low input (rca connector).
Amazon.com: PAC SNI15 Line Output Converter for Adding Amplifier: Car Electronics Amazon.com: PAC SNI15 Line Output Converter for Adding Amplifier: Car Electronics
Old Apr 26, 2021 | 02:10 PM
maxxym's Avatar
maxxym
Yeah, well, I already got this thing installed. Ugghhh
PAC SNI-35 Variable LOC Line Out...
Amazon Amazon
Old Apr 26, 2021 | 02:13 PM
travelingypsye
Thumbs up
PAC SNI-35 Variable LOC Line Out... https://www.amazon.com/dp/B001EAWS3W...p_mob_ap_share
That one works too so you are good.
Old Apr 26, 2021 | 02:21 PM
hamah's Avatar
hamah
wouldn't you only use that if your amp didn't have high-level inputs, or only had RCA inputs?
