DSP for two speakers in a batwing
Old Apr 28, 2021 | 12:18 PM
sublime_ac's Avatar
sublime_ac
Default DSP for two speakers in a batwing
I am curious if anybody is running a DSP for two speakers in a batwing.
Can you tell me about the source / amp / speakers used with the DSP?
What kind of tuning are you using the DSP for? I imagine subsonic filter, crossover settings and a lot of EQ... Anything else going on that I am not considering here?
What difference do you notice in the sound with the DSP while riding the motorcycle down the road?
I am trying to understand the use of a DSP in a two speaker install where there isn't time alignment etc. going on.
Thanks!
Old Apr 28, 2021 | 01:28 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
For me the main advantage was to warm up the sound. We have to push these speakers much harder than they would normally be run to hear them good at highway speeds. That tends to make them sound harsh. I was able to easily drop the mids a little bit to warm things up without really knowing much about what I was doing.
Crossover adjustments are very easy and precise with a DSP as well.
Old Apr 28, 2021 | 01:55 PM
sublime_ac's Avatar
sublime_ac
Do you have multiple tunes that you can switch between depending on where you are riding / how fast you're going? It'd be cool if there was a DSP that could take speed / wind noise in to consideration and retune on the fly.. I haven't seen such a beast yet..
Which DSP are you using?
Old Apr 28, 2021 | 02:14 PM
Hoyt 1911A1
I am using the Arc PSM. I had Iron Cross Audio add preamp outputs to my stock HK head unit and I feed it with that.
I hear what you are saying as far as multiple tunes. The Arc can store up to four different tunes that can be switched with an accessory remote ****. I don't get into that stuff though. About the only on the fly adjustment I do is a notch or two on the Bass and Fader depending on what helmet or jacket I am wearing and in some cases a windshield swap. As far as wind noise I have Automatic Volume Control to take care of that (cue the shouting and hollering that it shouldn't be used with amps).
For a simple two speaker setup I would be tempted to try the Dayton unit. It's a lot cheaper than the Arc and with only two RCAs going in and two going out it might not take up too much space.
On some other forums I have heard some guys say they like the MiniDSp 2x4 for simple setups but I have never tried one myself.
miniDSP 2x4
Old Apr 28, 2021 | 02:29 PM
cshocker's Avatar
cshocker
I know personally the ARC and Dayton can have multiple tunes. I only use 2 tunes, and that's just basically to cut my 10's off while on the hwy.
If you are wanting a tune for every type of riding situation, I think you're going to be chasing a very fast unicorn that might be hard to catch. And not sure it would be worth it. If I'm out riding and cranking tunes, I'm not going to be worrying about every different environment situation and adjust my tune to it. But that's just me.
Old Apr 28, 2021 | 02:52 PM
sublime_ac's Avatar
sublime_ac
was just dreaming of the perfect Unicorn, I totally get what you're saying. I am used to sacrifices in mobile audio, there is no perfect setup, especially on a motorcycle, so you have to compromise. I lived with the Arc / Hertz speakers for eight years, they served me well.. Now that one of the speakers gave up the ghost it's time for me to update some things, I am trying to determine how far I am going to take it.
The last stereo system I built was a year ago for the Corvette I recently sold, Alpine ILX-207, Arc DSP Pro, Arc 1200.6 to active Stereo Integrity three ways, Arc Audio 1100.1 to two JL 10w3's... The time alignment in the DSP REALLY made all of that come together, the system sounded good with Aerosmith, Metallica, Skrillex, Garth Brooks, Ice Cube, it really doesn't matter what I played it sounded great, sub-level was all I ever adjusted...
The motorcycle is a whole different proposition to me, I just want it to be clear, loud and RELIABLE with as much frequency bandwidth as possible. I am hoping that I can cross these GZ Yellows down to 60 or 70hz and push them hard.
Old Apr 28, 2021 | 03:21 PM
Thatdude596's Avatar
Thatdude596
200 watts crossover around 70 hertz. The more watts you push the higher the crossover
Old Apr 28, 2021 | 05:58 PM
Dsm Limited's Avatar
Dsm Limited
I have a 14 Limited. At the onset of my audio escapade, I had 2 fairing speakers and BT line leveler. Then went to 4 speakers and the line leveler. Hands down the addition of the Arc Psm made all the difference in sound quality.
That said, I have the Boom head unit that, at the time, inherently has a god awful eq curve built into the bin file. In addition, the eq curve drastically changed between run and accessory. The separate tunes between run and accessory allowed a different tune for each.
coldheart13
Sep 21, 2020 06:54 AM
bigreds1963ss
Audio Systems
Mar 24, 2015 10:04 PM
chgofirefighter
Audio Systems
Apr 12, 2014 10:45 PM
ClutchSmoker
Audio Systems
Mar 4, 2013 01:43 PM
jandb125
May 30, 2008 02:59 PM
