Ground for Amp
Old Jun 10, 2021 | 09:18 PM
Wolfmiester's Avatar
Wolfmiester
Default Ground for Amp
Another Stupid Question of the Day!!!!!
My Boss amp kit had an 4' ground. Not enough to run to the battery of my 2014 Ultra.
where does one place an Amp ground within the fairing? Speaker pod/Amp tray screws? Use power wire or purchase a 6' line instead?
​who gives 16' of red power wire and 4' of ground wire....JEEZ!!!
Old Jun 10, 2021 | 10:03 PM
qclassic's Avatar
qclassic
These kits are for car installation. Normally you run the the to battery take tank off to run OFC 8 ga power and ground to battery or ground to frame where the battery is grounded at.
You will need to remove the battery to get to that ground bolt
even run a 4 or 0 ga ground from battery to that factory ground bolt. Don't know what wattage your amp is though.
Old Jun 11, 2021 | 06:16 AM
mcdc1224's Avatar
mcdc1224
Look at the side of the neck for a opening. This will allow you run the wiring down the side of the backbone without removing the tank..
Old Jun 11, 2021 | 07:57 AM
chopper_man's Avatar
chopper_man
Ha! I went thru the same thing last year. Made no sense why they gave so much more positive than negative! I ordered a new ground wire off amazon. Firm believer in going directly to the battery.
Old Jun 11, 2021 | 08:04 AM
cshocker's Avatar
cshocker
It's cheap, that's why and it's for a car. I'm assuming it's not OCF wiring. I would return it and buy a kit for motorcycles, and one that is OFC.
Old Jun 11, 2021 | 09:33 AM
Tailwind's Avatar
Tailwind
No need to take the battery out on Rushmore's. Just access thru the brake side side cover. Saves a ton of time.
Or just ground directly to the battery.
T
Old Jun 11, 2021 | 09:48 AM
Keggr's Avatar
Keggr
Frame, or Battery? Thats the question. LOL
Old Jun 11, 2021 | 09:49 AM
teedoff65's Avatar
teedoff65
OP, you sure they didn't send you a used kit? Boss kits I see come with 8' power and ground cables.
Not sure if it's OFC or not...doesn't say either way.
Edit: nope sorry....misread it. 3ft of ground......stupid!
Old Jun 11, 2021 | 09:50 AM
Tailwind's Avatar
Tailwind
The designated grounding point on the frame that is just 4 inches in front of the battery OR the battery post. That's the answer.
Grounding anywhere else is asking for trouble.
T
Old Jun 11, 2021 | 08:07 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Reading about the ground point on the frame got me to thinking. Is there much advantage to beefing up the ground wire going from the battery to the frame on pre-Rushmore bikes if we already have everything going straight to the battery?
