Speaker Volume dB
Old Nov 8, 2021 | 07:50 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Most sled audio is going to have some floor noise if you get it loud enough to hear good out on the road. I was picky about that at first too but once I crank the bike I can't hear it anymore. Also if you add a DSP the floor noise will usually get louder. The reason being you are slightly amplifying the signal with the DSP before it gets fed to your amps.
I'm no whiz at this stuff but I have a good bit of floor noise from all of my speakers but none of my signals going into the amps are clipping at high volumes. I can live with that.
Old Nov 8, 2021 | 08:03 PM
teedoff65's Avatar
teedoff65
Agreed. I still have a slight bit myself, but really only from the horns I think. Can barely hear it before my music starts.
Old Nov 9, 2021 | 09:15 AM
Circa58's Avatar
Circa58
Mine is the same, small amount and then unnoticeable once the music comes on
Old Nov 9, 2021 | 10:21 AM
Old Sport's Avatar
Old Sport
When I did my set-up I used pink-noise through each pair of speakers to get them all to 98~100db with the HU about 75~80% output, then fine-tuned the overall balance with my ears.
Old Nov 9, 2021 | 05:38 PM
Circa58's Avatar
Circa58
Went back the dealer today, looks live everything is working now.....CB = yes, Carplay = yes, 20 presets = yes, Sirius XM = yes,, Fader = yes, Rockford Fosgate 1-amp 4 speakers = yes....gonna pull the fairing tomorrow and jump back into tuning :-) and relocate my amp fuse location
Old Nov 10, 2021 | 08:56 AM
Circa58's Avatar
Circa58
Went back to the dealer, after much back and forth because they dont understand how this works, I think they have it correctly flashed now :-)
Going to reset voltages based on you'alls comments, and I ran a new 4-gauge up the hollow tube that I didn't know existed :-) so thanks for the help
Old Nov 10, 2021 | 12:47 PM
Circa58's Avatar
Circa58
Ok so I snuck out for a bit this morning, ran a new 4-gauge power line thru the frame, and cleaned all of the wiring up, and was able to get 27-volts using the -5dB 1k test tone, Master Slider at -5 and all EQ Flat.
Sounds pretty awesome as is, so I'm anxious to get the Mobile Tools RTA with a Dayton iMM-6 microphone on it and see what the Pink Noise says, then go from there.
Thanks everyone for your patience.
Old Nov 10, 2021 | 08:31 PM
rblahetka's Avatar
rblahetka
Originally Posted by Circa58
Ahhhh... I was taking any and all fuzz out, it was quite a ways from squaring off the wave, I'm certain it will go to 27volts now, thanks
Ive been doing the same thing and questioning my stinger 700 on why anything above 19.5-20 was messy. Never knew I could go higher. Guess I’m pulling the fairing off again this weekend.
Old Nov 11, 2021 | 12:17 AM
hamah's Avatar
hamah
While it's possible to get so much harmonic distortion that it's audible before you get clipping it's really rare (a bad amp or noisy source might cause this). You'll typically get clipping long before you'll ever hear harmonic distortion and by far the most common problem you come across while setting gains is clipping. So yeah, crank the gains until you have a clipped signal and then back it off until you don't. Easy peasy.
mrmagloo
Audio Systems
19
Mar 12, 2022 04:12 AM
GunslingersNation1
Audio Systems
Jul 12, 2020 11:03 AM
Xarmy2005
Audio Systems
Feb 4, 2018 09:45 PM
Tim S.G.
2014-2024 Touring Models
11
May 22, 2014 05:12 PM
danj67
Audio Systems
Jul 30, 2013 07:06 AM
