Addi g lids this winter, I run the gz yellow basket in the faring, haven't seen alot of input on the 6x9s here, opinions?, or other 6x9s that you think would be better?. Running a SD 800.4
can I run at 2 ohm even with my gz's being 4 ohm speakers?
With your 800.4? No, I run the 1200.4 2 ohm. I bridge and run parallel. That gives me 2x600W. It comes out to 300 per speaker and I have the Gz's at about 225W. I think at 200W they would sound great but the 6x9' should take 250W tuned right.
I have this exact setup in a 2020 CVO Road Glide. 6.5" Yellows in the fairing, 6x9" Yellows in the lids, and an SD 800.4 EVOPS. It was installed back in June of this year and I've put about 30,000 miles on the system already. That includes plenty of hard rain. The system sounds fantastic and is holding up to the elements just fine. For what it's worth, I did have the installer put hydrophobic speaker cloth on the back side of all speaker grills. Very cheap insurance and it doesn't affect sound quality at all. $16 bucks from Amazon and one package was enough for all grills.
No DSP, but my EQ was flashed to a flatter setting, and he did comprehensively tune it. The most I ever need to turn it up is with 5-6 hashmarks showing and that's if we're on the interstate doing 85+. I would even consider this a somewhat budget friendly system. You've got most of the components already, I think the GZ 6x9's would round out your system just fine. I think the 6x9 sound better than the 6.5".
