Question about Ohms
Old Jan 1, 2023 | 07:25 PM
aaazdaddy's Avatar
aaazdaddy
Default Question about Ohms
I came across a great deal on MMATS PA601's for $59 each but they are 8 Ohms. I'm running a '22 RGS with a Rockford Fosgate TM400X4AD 4 Channel AMP (Out of my old bike).
Seems like everyone is running 4 Ohm, and I'm reading that you don't want your speakers to be LESS than that, but what about more? Obviously out of my scope...
Thanks in advance,
Bob
Old Jan 1, 2023 | 07:30 PM
cshocker's Avatar
cshocker
Thanks in advance,
Bob
They are the mid woofers and not coax correct?
Old Jan 1, 2023 | 07:36 PM
aaazdaddy's Avatar
aaazdaddy
Yes, that does appear to be the case, and that said didn't know if they would be best for this application without the tweeters. Perhaps I'd be better off to get the PA601.cx's or the LS65cx's...;
Old Jan 1, 2023 | 07:39 PM
cshocker's Avatar
cshocker
You wouldn’t want to run them without separate horns/tweeters.
The PA601cx would be best if only running 2 speakers
Old Jan 1, 2023 | 07:58 PM
07UltraGuy's Avatar
07UltraGuy
If the impedance of your proposed speakers is exactly double the impedance of the existing speakers, then if/when swapped, your radio will produce exactly half of the volume it did before the swap.
Bottom line is that the system is designed for a particular impedance.
The older Harley audio used 2 Ohm speakers as a means to limit the number of aftermarket replacement options, essentially giving the MOCO another way to control our wallets and their product line.
Inop
Audio Systems
Sep 9, 2022 02:47 PM
chopper_man
Audio Systems
May 5, 2020 08:19 PM
rlager
Audio Systems
13
Apr 4, 2020 02:54 PM
Cinchup
Audio Systems
11
Dec 26, 2019 08:38 AM
$tonecold
Audio Systems
Jan 27, 2014 12:47 PM
