Audio Newbie. Please Help!
Old Feb 5, 2024 | 05:26 PM
Knucks22's Avatar
Knucks22
6th Gear
Default Audio Newbie. Please Help!
I have a 2013 Road Glide. I bought the bike used and it had no head unit or speakers in it. So just to get something into it, I got the Rockford Fosgate PMX-HD9813 head unit with the Rockford Fosgate TMS6RG fairing speakers. It was a local shop that had the package for $700 together.
I have watched a ton of videos, read some forums and threads and have some questions.
I want to swap to some DB Drive speakers and add a Sound Digitial Evo 800.4 amp. I may go with some bag lid 6x9's down the road but have no need for those right now.
Outside of the speakers, amp, speaker adapters to mount and an amp wiring kit... do I need anything else. I have seen some mentions of line output converter, do I need that with the Rockford head unit?. Are there better equipment options that pair up better with that head unit?
Looking for any and all advice/suggestions!
Thanks in advance
Old Feb 5, 2024 | 10:25 PM
madhunter60's Avatar
madhunter60
The headunit should have came with a plug with rca 's on one end.This plugs into the headunit behind a little plate you have to remove if I remember right. Then you can use rca's to connect to the amp. Without needing a line out converter.
Old Feb 5, 2024 | 10:36 PM
madhunter60
Old Feb 6, 2024 | 02:23 AM
Knucks22's Avatar
Knucks22
6th Gear
Originally Posted by madhunter60
Ok. I figured as much with the RCA’s.
Thank you!
Old Feb 6, 2024 | 07:35 AM
cshocker's Avatar
cshocker
What DB speakers? Moto CD's?
Old Feb 6, 2024 | 11:17 AM
Knucks22's Avatar
Knucks22
6th Gear
That was my first thought. I did look at the Euphoria Xperts as well.
Old Feb 6, 2024 | 12:15 PM
cshocker's Avatar
cshocker
I would go with something else if they are going to be your only speaker. They are a good speaker, just not very warm sounded at all when they are solo.
If you're looking for one of the best (to my ears) coax fairing speaker right now, would be the Euphoria EX6NPS-CF. They are nice.
They EX6NCX are nice well, but not as warm as the NPS. But would work well as fairing only setup.
Keep in mind, if you add lid speakers down the road, that 800.4 will be light on power for all 4 speakers.
jasilva
Audio Systems
Mar 6, 2022 08:48 PM
Catahoula
Audio Systems
Aug 31, 2020 09:32 PM
langwilliams
Audio Systems
11
Jun 20, 2018 06:08 AM
jjpish
Audio Systems
33
Jul 3, 2017 12:08 PM
KDUBYA
Audio Systems
Apr 16, 2013 01:19 PM
