Soundstream PN4.520D FM EMI reduction
Old Jun 17, 2013 | 09:01 PM
  #51
UltraNutZ's Avatar
UltraNutZ
Originally Posted by Turk05
Looks like this weekend before I get to all of this. One thing to note is that i am not using the RCA connections, I am using the other white wire harness that plugs into the amp. This harness also has a "ground" wire which I have hooked up to the aux ground on the headlight harness. Could this set up be an issue? I'm only running one pair of 651's with this amp...
Would RCA cords help?
Would removing the little harness ground help? Or be a bad idea?
RCAs are always a cleaner signal however i'm not sure if it will help with the FM issues. The ground wires on the white plugs are not to be used unless you have ground noise. I would certainly remove them.
Old Jun 17, 2013 | 09:17 PM
  #52
Gone Riding's Avatar
Gone Riding
No, the little harness ground should be fine. You might put 2 wraps of that harness through a ferrite if you can.
I can make no promises that any of this will show a significant improvement. I have not tested the effectiveness of these additional steps. From what I've seen most of the noise is on the power lines, but there is some on the speaker wires as well. The chassis ground bit is just good design process. Again, it may or may not help much. It's just the stuff that I'd do if I wanted to go all out to reduce the noise level. There's a fair chance that some amps just make too much noise to damp out with this approach.
Old Jun 17, 2013 | 09:18 PM
  #53
Gone Riding
I stand corrected... UltraNutZ is absolutely the authority here.
Old Nov 15, 2013 | 03:19 AM
  #54
WDE's Avatar
WDE
When you say "2 wraps in the same direction"...
does that mean the direction of the current flow through the wires should be in the same direction as it goes through the core?
Battery--->Power Wire--->Core(in left, out right)--->Amp In--->Ground out--->Ground Wire--->Core (in left, out right)--->Frame
Or does the "same direction" mean the relative direction the wires are running to the amp?
Battery---->..... ---->Amp
............... Core.............
Frame ---->..... ---->Amp
Old Nov 15, 2013 | 05:09 AM
  #55
Pioneer74's Avatar
Pioneer74
I tried every way possible to make this work. Even bought bigger cores to have more wraps. Never made any improvement.
Good luck.
Old Nov 15, 2013 | 07:21 AM
  #56
UltraNutZ's Avatar
UltraNutZ
I don't use FM so it never bothered me nor did I realize the interference until it was brought to my attention here.
But as Pioneer74 stated, it doesn't matter, nothing seems to help. Just is what it is with Class D amps.
Old Nov 15, 2013 | 07:54 AM
  #57
Pioneer74's Avatar
Pioneer74
Exactly. The Soundstream 4.520 is a very powerful and inexpensive amp, but there are tradeoffs. You have to expect that you will lose FM and WB reception. There is no way around it.
just plain john
Audio Systems
May 27, 2018 10:20 AM
CrackOfDawn
Audio Systems
Jun 23, 2017 02:44 PM
Cornutjim
Audio Systems
May 10, 2016 05:01 AM
roklock
Audio Systems
Mar 2, 2015 11:24 AM
Scottie83
Apr 8, 2011 08:26 PM
