Amp status light question
Old Jun 27, 2014 | 09:15 AM
1HD2NV's Avatar
1HD2NV
Default Amp status light question
Been awhile since I installed a system, assume this light remains on all the time, even with ignition switch off?
Old Jun 27, 2014 | 09:26 AM
Eshaw301's Avatar
Eshaw301
No, if hooked up correctly (to the acc or headlight wire), the amp should only come on when the key is turned on. If it stays on or comes on any other time, then you have your wiring hooked up wrong.
Old Jun 27, 2014 | 10:54 AM
1HD2NV's Avatar
1HD2NV
Power & ground directly to the battery, amp enable wire to "Power Control" wire on Kenwood HU. Kenwood manual states: When using the optional power amplifier, connect this wire to it's power control terminal. There was a stearing remote control wire on the HU that I did not think applied here.
Old Jun 27, 2014 | 11:43 AM
tdgriff's Avatar
tdgriff
Mine is on all the time. Never any trouble.
Old Jun 27, 2014 | 11:45 AM
tdgriff's Avatar
tdgriff
I called Mike from BT and he told me the light will stay on with the amps they sell. It will not drane the battery at all
Michael R Moore
Audio Systems
Jan 23, 2019 07:40 PM
SoloRider67
Audio Systems
Apr 12, 2018 10:00 PM
DeneFXDWG
Audio Systems
Apr 15, 2014 11:02 AM
INZANE
Aug 27, 2009 08:35 PM
zippo2
May 4, 2009 11:21 AM
