Water Stains on Windshield
Old Nov 27, 2024 | 03:24 PM
Geoff's Avatar
Geoff
Default Water Stains on Windshield
Any suggestions for removing water stains from a plexiglass windshield? I tried using white vinegar, Dawn dish soap, and Plexus (specialized plexiglass cleaner). Nothing worked.
Old Nov 27, 2024 | 03:27 PM
WP50's Avatar
WP50
How old is the shield?
Age takes it's toll.
Pic?
WP
Old Nov 28, 2024 | 06:26 AM
Steelie68's Avatar
Steelie68
I believe that Griot’s Garage makes a water spot remover. Good luck.
Old Nov 28, 2024 | 06:50 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Are they water stains or etched in marks from acid rain etc.? Magnifying glass looking at them will tell you.
Usually using the same water that created the water stains will remove dried water stains unless they are etched into the plexiglass.
If etched into the plexiglass then mechanical methods may remove them but you should do the complete windshield so everything is even.
If mechanical methods do not work it is time for a new windshield.
Old Nov 28, 2024 | 08:48 AM
bustert's Avatar
bustert
try glass wax
most quality screens are UV inhibited. they also make restore kits for auto head lights.
Old Nov 28, 2024 | 09:15 AM
twoglides13's Avatar
twoglides13
Novus 1 should do it, Novus 2 is a bit more aggressive.
Old Nov 28, 2024 | 09:23 AM
zoozoo's Avatar
zoozoo
I use this. It's the best I've ever used.
https://www.walmart.com/ip/Sprayway-...0&from=/search
Old Nov 29, 2024 | 01:40 PM
CaffeineBuzz's Avatar
CaffeineBuzz
what can happen to a windshield is it get's etched....the guts of a lot of bugs can be highly acidic...they can compromise the surface of a clear coat or a windshield and chemically create pits in the surface....no amount of scrubbing can remove these as they are technically not a contaminant
you've got to be able to look at it closely and determine weather the surface of the plastic is etched or if you have contaminants on the surface that can be removed
Old Nov 30, 2024 | 06:45 AM
smitty901's Avatar
smitty901
If they don't come off it is not stain but etching most like from soap or other cleaner used to was the bike. Not a darn thing you can do for it.
Old Dec 4, 2024 | 08:12 AM
Kenny94945's Avatar
Kenny94945
If etched... well, you may be f88ked.
I have had good luck with Mcquires (sp) Plastic Cleaner flowed by Plastic Polish, by hand.
Many compare Plexis to Mcquires, so this suggestion may not work.
Groits is a branded name with good products, so a specific water stain remover may be a good try.
Then you are at a "harder level", if by hand, try courser compound, polish, and plastic finishing polish, yet again you may be f88ked.
If etched, you may be at a point to try wet sanding and machine polishing, but there is a risk.
Good luck.
popcorn13
Aug 30, 2016 09:10 AM
flipbel
Jan 4, 2014 10:39 AM
watercop
Jul 6, 2009 09:09 AM
Chips
May 9, 2009 09:47 AM
DanLPN
Screamin Eagle CVO Models
Mar 27, 2009 08:02 AM
