Fender Bracket/Lift Question
Old Mar 27, 2015 | 01:06 AM
cdg097's Avatar
cdg097
Originally Posted by rustang
do you have a pancake/scissor jack in your car?
$25 or so at atuozone if not.
My ATV lift is quite a bit lower than the scissor jack that is in my truck, even in the lowest position, so that's a no-go.
Originally Posted by Mascman
Couldn't have racked your brain too much if you thought to use the lift after removing the shocks!
I know you said you can't budge it, but could you start it up and CAREFULLY ride it up onto a 2x4 or two under your tire?
I had lower shocks before and the only way I could get my lift under it was to get something under the tire.
I tried getting the lift under there BEFORE I took the shocks off. It was too low even before. Riding it is out of the question, I don't even want to move it because the hardware from the license plate mount and the taillight are already rubbing the tire. I suppose moving it by hand onto a 2x4 or two won't be that big a deal though. Thanks for the idea.
Originally Posted by OldEnuf2NoBtr
Roll the front wheel up on a piece of 2x6 or 2x8 or whatever and then get the jack under it. Have someone brace the board so it doesn't want to scoot on you.
I appreciate the idea, that might be less difficult than running ratchet straps off the ceiling.
easystreet13
Sep 23, 2017 05:52 PM
Beetroot McKinnley
Jun 4, 2016 10:27 AM
DirtyThirty
Mar 20, 2011 09:49 PM
hellfish
Apr 4, 2009 07:05 AM
CaptEvo
Apr 1, 2007 12:18 PM
