'97 Dyna Throttle Cables
Old Aug 21, 2015 | 10:51 AM
boogieman97's Avatar
boogieman97
Default '97 Dyna Throttle Cables
The throttle cables at the control are really loose. Is this for steering purposes or are they supposed to be tight and immovable?
Old Aug 21, 2015 | 11:15 AM
skinman13's Avatar
skinman13
if the retaining rings are good and the control cables ain't falling out of the lower switch housing then I would think that you are good...
Old Aug 21, 2015 | 11:18 AM
nevil's Avatar
nevil
They have to be loose enough so they don't bind when the bars are turned all the way to the left or right.
Don't really know what you mean by really loose, but how much play do they have? Since it's an easy job, just might as well adjust them. That way if they're not right you'll have solved that issue.
Old Aug 23, 2015 | 12:48 PM
boogieman97
By loose I mean they swivel quite easily, I guess for steering purposes. The cables turn 90* out of the control housing. The metal end where the cables exit has about 1/4" to 3/8" up and down play. They seem secure, just a loose fit. I don't remember that on any of my other bikes. Just had dealer service done and they didn't mention any problem.
Or is this just another Harley "they all do that" moment?
Thanks guys
TwoBlue02
Dec 29, 2012 05:00 PM
klf33
Sep 24, 2009 04:41 PM
Samber79
Mar 14, 2009 12:28 PM
nickdv9
Apr 25, 2007 08:29 PM
sparky_mo
Apr 10, 2007 12:50 AM
