New Low Rider S
Old May 28, 2016 | 10:45 AM
  #1081
203Cree's Avatar
203Cree
Originally Posted by Mchad
You have single front disk. FXDLS is dual. Won't work.
Actually it would. The FXDB hub is tapped for duals.
Old May 28, 2016 | 10:53 AM
  #1082
multihdrdr's Avatar
multihdrdr
It will work for him...That's really what he's concerned about
Old May 28, 2016 | 01:49 PM
  #1083
WH1_T-type's Avatar
WH1_T-type
Originally Posted by Tanium
Got a photo with the exhaust finally.
I like that. Do you have a link? Is it loud? I'm really liking how quiet the S is stock
Old May 28, 2016 | 03:26 PM
  #1084
stupac_'s Avatar
stupac_
6th Gear
You sure it's not the low voltage error? I find the clutch grabs sometimes and the starter draws a lot which will cause that. I've learned to flip to neutral when starting - since doing that no more errors.
Originally Posted by ktp1598
I got it the other day. I pushed the start switch after filling up with gas but let off too soon before it could start. I just waited a few seconds and it started fine. The starter is labored more during a hot start so I would think we'll all see that error every now and then. Doesn't bother me unless I get stranded.
Cheers Guys, went by the dealer - they said the error normally means that the speedo and ECU are out of sync... but couldn't explain why it wouldn't start.. or why it would even be out of sync. Just told me to keep an eye on it.
I cant remember if i was in Neutral or not, so if it happens again i'll make a note. Maybe i did let go of start button too soon, not sure. it was ok again after a minute. Just a bit concerned as travelling across Europe next week.. don't want to be stranded in another country.
I'm sure it's something to do with how hot it runs stock... that shitty EITMS had kicked in 10mins before.
Old May 28, 2016 | 06:52 PM
  #1085
blackfriar's Avatar
blackfriar
My dealer checked with Cobra and their RPT 3 slip on mufflers will fit. I am having them installed after my 1000 mile service is done next week.
Old May 28, 2016 | 10:45 PM
  #1086
SlowriderInOz's Avatar
SlowriderInOz
you can turn the EITMS off. Ignition on, roll throttle past off and the cruise control light will begin to flash. Green=EITMS on. Amber = EITMS off. It will alternate between on and off as you roll the throttle back.
Old May 29, 2016 | 06:14 AM
  #1087
Mchad's Avatar
Mchad
I wonder if it's "vin" err or v in err - voltage insufficient? I'm just guessing...
Old May 29, 2016 | 07:40 AM
  #1088
Shaved Ice's Avatar
Shaved Ice
750miles... got an error code. Trying to start bike when it's hot and getting "vinerror" any body had or seen this? Guess it's back to the dealer!!!
Do you have a tuner? I installed a Screaming Eagle Race Tuner (SERT) on my old Fatbob and got a dynotune. It ran great but had the same issue and code you describe. The tech had turned off some sensor when doing the tune and never turned it back on. They turned it back on and the problem went away. I really wished I could remember what the actual name of it was.
Old May 29, 2016 | 10:53 AM
  #1089
NorthWestern's Avatar
NorthWestern
It is very loud.
I got mine at Revzilla, it is the Bassani Road Rage Mega Power.
Old May 29, 2016 | 10:54 AM
  #1090
NorthWestern
I do the same.
